i am planning a build right now but i need help. i am going to run 8 Re audio re series 12's and 2 crunch pzi1000/1's. i want to run 4 subs off each amo.
P 1000.1
1000W 1-Channel A/B Class Mono Amplifier
250W x 1-Ch @ 4-Ohms or
500W x 1-Ch @ 2-Ohms or
1000W x 1-Ch @ 1-Ohm Dynamic Music Watts
Includes Remote Mountable Bass Control
these are the stats on the amps. how can i wire these for the best power. the subs are dual 4 ohm v.c.
secondly the subs call for 1.5 cu.ft @35 htz. i will be playing music and doing a few shows with this set-up. i want it to be as loud as humanly possibly on music. is 35htz the best tuning for the box for this or should i go higher or lower. i am going to need all the help i can get.
should i fiberglass and all thread or would that not be needed in my case. i know that these are not the loudest woofers out there but at the price i can get them for i cant beat it. i know i will be louder than the 2 l5 15's i planned on running with these same amps. and should i really do 1.5 cu.ft for each sub or do more or less.
sorry for all the questions but i want to do this the right way the first time.
----reference's----
meade916
with everyone looking i know one of oyu have some input.
somewhere around 1.50 to 1.75 each. slot port all the way across the bottom tuned to 38ish.
Michael Hughes = 6X SPL World Champion - Loudest on the planet in db Drag, USACi, and IASCA.
straigh tfrom a legend how much would you charge me for plans and a cut sheet?
----reference's----
meade916
with running 4 per amp your only going to be able to get 2 ohms so it wont be putting out 1000
I couldnt draw up something like that without having the car to measure. Just drive it over here. I can throw that box together in about an hour. :)
so what do oyu recommend then
----reference's----
meade916
believe me if you were in ohio i would be there first thing monday morning
----reference's----
meade916
go ahead and do 8 per amp
i only have room for 8, 16 wont fit in my car. i am gonna have a very hard time with 8.
----reference's----
meade916
  • Who's Online   1 Member, 1 Anonymous (See full list)
