Slow 07 Trailblazer Updated with new set up
That's some solid equipment!
2012 Silverado ext cab
Kenwood DDX470
XS D3400 (starter)
XS D375 (under passenger seat)
XS d3100
Mechman 240
Big three
SMD VM-1
All SHCA wire
80 sq feet of Damplifier
6.5 Crescendo CZ's (front doors) (needed)
5..25 Crescendo CZ's (back door) (needed)
Crescendo 125.4 (needed)
Sundown Zv4 12
Skar 4500 (2ohm)
Ran my speaker wire up to the rear doors and to the front doors. Crossovers are just sitting under the back compartment. Box will cover all the wires and power and ground will be off to the side. May be able to put the box in and the 3100 tomorrow, then next weekend if I can get some more nice weather will install the mids and highs. Of course by doing that I will have to do it twice since I will have to second skin the doors but at least it will be better than the stock speakers.
http://www.stevemeadedesigns.com/board/topic/177477-slowboring-07-trailblazer-build/
Pioneer DEH-80PRS
PRV 8MR400-NDY (eight)
PRV TW350Ti (6)
Sky High 1/0 OFC, 12 gauge and 8 gauge
TM Metalworkz battery terminals
120 sqft Hushmat
XS Power D3100 (6)
Singer 350 Amp Alt
Singer 320 (2)
American Bass SQL3200
JL Audio JX360/4
Crossfire XS 8K (2)
DC Audio XL 15s (6)
took the onstar box out. Never used it and don't think I ever will. Put the 3sixty.3 in its place and ran power to the back, rca's to the back and then to the front. Not in the radio yet but there at least up there. Only have to run my relay wire back and wire for the voltmeter on the drivers side I think. Hope so anyways. My motivation for running wires right now is about none.
Pioneer DEH-80PRS
PRV TW350Ti (6)
120 sqft Hushmat
XS Power D3100 (6)
Singer 350 Amp Alt
Singer 320 (2)
JL Audio JX360/4
Crossfire XS 8K (2)
DC Audio XL 15s (6)
IMG_1857_zpse828da89.jpgIMG_1856_zps33112bae.jpgjust a couple more here
Pioneer DEH-80PRS
PRV TW350Ti (6)
120 sqft Hushmat
XS Power D3100 (6)
Singer 350 Amp Alt
Singer 320 (2)
JL Audio JX360/4
Crossfire XS 8K (2)
DC Audio XL 15s (6)
Let me know if you have voltage issues (up and down) with or without load because you have that ground sensor thing under the hood and you shouldn't add extra grounds.
2007 Chevy Tahoe (SOLD)
2 ~ DC Audio 5.0K @0.67
3 ~ DC Audio 5.0K @1.0
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
320+ Sq. Ft. Sound Deadener
Pioneer AVH-X5500BHS
Like the equipment! I can't wait to see where this is going.
That's an awesome song you had pulled up on the h/u btw :rockwoot:
Dorm room setup:
SQ SDC2.5 12" @ 8 ohms
Klipsch 300 watt home theater sub amp
Marantz 1030 amplifier
Future car build:
Audio Technix 1200.1d
Fi SSD 12 w/ cooling and flatwind coil
6th order dual reflex enclosure
No issue that I know of yet. Once installed started it up and was at 14.9/15. Still haven't really went anywhere though yet with it. Just been sitting in the driveway. I did know you weren't suppose to do more grounds. Guess I'll just watch it really good just to be on the safe side. I can always take the frame ground and disconnect it from the terminal to see what it does. Maybe I'll look at that tomorrow.
Pioneer DEH-80PRS
PRV TW350Ti (6)
120 sqft Hushmat
XS Power D3100 (6)
Singer 350 Amp Alt
Singer 320 (2)
JL Audio JX360/4
Crossfire XS 8K (2)
DC Audio XL 15s (6)
No worries man, not hatin, silently tuned in, haha. I got that same dumbass ground sensor and tried adding grounds anyways and my voltage was crazy up and down, maybe not fast or right away, sometimes good for a couple days then it was way low for a long drive etc. but still. I started eliminating grounds one by one hoping I could get it in check and it never acted right until I did what Mechman suggested (I have a Mechman alt) to a *T*. That is just my own personal experience. I even squeezed a 8 guage ground through that sensor as an added body ground and to me it should have worked flawlessly because it went through the sensor right? Wrong. I mean I hope your works without having to remove things but for me i got 1 ground running from Alt case, to battery (through sensor), and then SHCA 2/0 front to back and straight to battery bank, and then bat to batt to batt. Rear batts only grounded to themselves. i tried ground in the rear, amps to grounds and not negative terminals on batts (they are currently on neg terminals on batts) and seriously, for me, there is pretty much only one ground and it starts at the alt, goes through the sensor, and then just links all the batteries in series, any other way (I tried several over the course of weeks/months) and my voltage acted goofy as all hell.
That is just my experience, yours could be different and I hope it is. Good luck
oh and tuned in, lol
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
I'll mess with it tomorrow. Still need to put my voltmeter in so will see how that goes. Hopefully it works out ok. I only have two grounds running through that sensor, one 1/0 and the stock one. (not to the body though, I have that separate. Tomorrow I will toss the box in and hook the second battery up. Maybe that will change it. More to follow.........
Pioneer DEH-80PRS
PRV TW350Ti (6)
120 sqft Hushmat
XS Power D3100 (6)
Singer 350 Amp Alt
Singer 320 (2)
JL Audio JX360/4
Crossfire XS 8K (2)
DC Audio XL 15s (6)
Cool, thanks bro, and yea, that factory one has to go through it also. Add the 1/0 aftermarket and there's not much room, that's the only reason I squeezed a 8 AWG through (but removed later)
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
  • Who's Online   0 Members, 0 Anonymous, 1273 Guests (See full list)
