My Wall Volume correct?
ChevyBoy95
Ok, so port length is actually 22". (re did the port wall a bit to make the blue line exactly 5.75 as well.
Only weird thing, have had this happen to me a lot in torres, net volumes dont match.... ever.
With on paper calc I get ~15 cubes of net volume for the subwoofers. In torres im at 13. And yes, port is on 3 walls like it should, set the thickness correctly, accounted for sub displacement on both on paper calc and torres.
Makes me want to get BB Pro 6 or something dependable.
SInce your blue distance is so close to your red measurement you port probably end at blue or at some unknown unknowable spot between blue and green.
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
I'd be more concerned about the sub closer to your port unloading.
CURRENT SYSTEM:
  • Alternator:
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
    • Mids RE XXX 6.5c
Build Log
that isnt final. just wanted a visual representation. both subs will be on passenger side
i redid the port to make the blue the end.
  • Who's Online   0 Members, 0 Anonymous, 1333 Guests (See full list)
