xan326 Posted November 5, 2013 Author Report Posted November 5, 2013 the jl13.5 i have used many times it is not a bad sub, but it just lacks compared to other subs as it is designed for very small installed like behind a seat in a truck if this is what you were doing it would be 1 of the better option as it is not, it is not and going the rout your looking is called active http://lmgtfy.com/?q=how+to+do+an+active+setup+smd most people won't do this as the time and involved you need 1ch per speaker or per set of same speakers on same area and is designed for getting loud i.e. keeping up with 20k sub stage I've never had an issue with 2 set of comps keeping you with 5k sub stages for the price and money you will be investing but if you want to o that route this is what idd be doing front 2x pwx 8" 4ohm on a q2-200 4x pwx 6.5 4ohm on a q4-120 2x ft1 8ohm rear 2x pwx 6.5 4ohm on a q4-120 2x ft18ohm You DO NOT need a processor any anything like that for ur first install/system. Just buy decent quality speakers and a headunit first and u can add a processor later if needed. Look at sonic electronix they have a huge range of gear. For example: http://www.sonicelectronix.com/cat_i1039_car-audio-packages.html. Look here they have good packages with all u need , crossovers included to go with speakers etc. I'd have to look to see what my car can even handle in the sizes, I know my deck right now has 6.5"s and 6x9"s, front doors have 4"s but there's this weird bracket that I need to eventually measure the mounts on and figure what I can get in there, the deck can be cut to hold larger speakers. I wonder how hard it'd be to take the plastic off my door panels and just fiberglass new ones, if thats even possible with my car. The fronts, right now the only spot is the doors. The kick panels are too small, unless I go on the inside of the console dash center piece thing but that'll end up not working either. I figured at most if I needed to I can fit three 6.5"s in my doors side by side, seat wont interfere unless it's all the way forward, but nobody would move the seat, and I figured I could go 2 high, so if I do glass the doors I could possibly find a way to do the two 8"s and four 6.5"s. In the back, I don't know where to put the tweets, unless they go on the c pillars. Do you think in the front the tweeters could be mounted somewhere other then the a pillars? My a pillars are just weird and it wouldn't work, now if I had power mirrors I could just put them on the inside of those on that triangle piece. Unless you can tell me of some components that are just as good as the Crescendo mids and tweets (especially at the price) I'd consider it. That sonic electronix link has been nothing but subs so far, the only speakers on there are coax.
SQ SUBARU Posted November 5, 2013 Report Posted November 5, 2013 Look at focal, morel,hertz, alpine type c or type r, infinity components I haven't heard the cresedo so can't comment but I'd recommend any of the ones I've listed, they all come with passive crossover networks too so u can't go wrong, then just find an appropriate 4 channel amp to power them, if u want speakers in the back, just get coaxial and run the off the headunit amp Ipad mini as main source unit, w/ Kenwood KDC-U7056BT,Digital Designs CS6.5 2 way components, Alpine PDX-F4 4 channel & PDX-M6 mono, x1 Jbl P1224 12", single ported box @ 34hz, front doors + trunk sound deadened w/ dynamat xtreme,all knukonceptz wiring/fusing. *In progress - Audison bit ten d dsp, fully optical.
john253a Posted November 5, 2013 Report Posted November 5, 2013 what cart do you have? and how much do you have to spend right now? what head unit do you have with mdl number?
xan326 Posted November 5, 2013 Author Report Posted November 5, 2013 Look at focal, morel,hertz, alpine type c or type r, infinity components I haven't heard the cresedo so can't comment but I'd recommend any of the ones I've listed, they all come with passive crossover networks too so u can't go wrong, then just find an appropriate 4 channel amp to power them, if u want speakers in the back, just get coaxial and run the off the headunit amp what cart do you have? and how much do you have to spend right now? what head unit do you have with mdl number? Headunit amp is a joke, it's only 50w and I've found a ton of speakers over 50w. What do you mean by cart? Right now I only have $100, and I'm looking for a job. Being in highschool trying to get a job sucks. And my head unit is the Pioneer DEH-6600BS
john253a Posted November 5, 2013 Report Posted November 5, 2013 car not cart, you say you have kicker ds where are they you say front is 4" and rear is 6.5 and 6x9" is this correct as for you h/u don't worry about the 50w or 14rms that don't mean shit when you amp stuff all you care about is 3 set of rca's to witch you have, and 2v pre out (not the best but more then fine)
SQ SUBARU Posted November 5, 2013 Report Posted November 5, 2013 For components... Spend a good amount on these as its 70% of what u hear up front wear ur sitting: http://www.sonicelectronix.com/item_13969_Infinity-Kappa-60.9cs.html Or this http://www.sonicelectronix.com/item_34364_Alpine-SPR-60C.html For a 4 channel amp to power the components. http://www.sonicelectronix.com/item_19566_Rockford-Fosgate-PRIME-R300-4.html Mono amp to power the sub: http://www.sonicelectronix.com/item_34764_Rockford-Fosgate-R1200-1D.html Subs: Either 2 10 inch or a single 12 will work fine in a sealed box, u can change later to a ported box if u want which gives u + 3db. 2 of these http://www.sonicelectronix.com/item_69578_JL-Audio-10W1v3-2.html Or 2 of these http://www.sonicelectronix.com/item_45534_Alpine-SWE-10S4.html Or a single 12 alpine would be good for a daily setup substage. http://www.sonicelectronix.com/item_45521_Alpine-SWR-12D4.html Add a headunit onto that (pioneer, kenwood) with 3! Preouts, u can't go wrong. Leave the rear speakers out and just have the 2 way components up front, and later if u want it louder add rear fill. And it will save u money too. If u don't think components are the way to go then just get some coaxial speakers in the front doors. But components sound that much better IMO and more bassy up front, so that's your mid tight bass ur looking for. Later on u can deaden the doors to help stiffen them so the components mid bass sounds even better. U can keep some of the gear u have now if u want and just upgrade gear with the pay check. Add 2 amps kits to that's say $60 each thats around 1200$ total roughly. U can spend more on better quality gear but just get some decent branded middle range stuff and u can upgrade later but u can't go wrong with anything from sonic since u don't have a local store, instead of kicker etc. just my opinion. Good luck. Ipad mini as main source unit, w/ Kenwood KDC-U7056BT,Digital Designs CS6.5 2 way components, Alpine PDX-F4 4 channel & PDX-M6 mono, x1 Jbl P1224 12", single ported box @ 34hz, front doors + trunk sound deadened w/ dynamat xtreme,all knukonceptz wiring/fusing. *In progress - Audison bit ten d dsp, fully optical.
xan326 Posted November 5, 2013 Author Report Posted November 5, 2013 I have a 95 toyota corolla, or ae101. The stock mounts are 4" in the front, 6.5" in the deck towards the outside, and 6x9"s in the deck towards the inside. I only have the 6.5"s in. And in this case would the speaker wire be better then the rca's? And if speaker wire is better, should I replace the old factory wire? I don't know if that stuff is the best or not, plus all the wiring needs to be cleaned up anyways.
xan326 Posted November 5, 2013 Author Report Posted November 5, 2013 For components... Spend a good amount on these as its 70% of what u hear up front wear ur sitting: Add a headunit onto that (pioneer, kenwood) with 3! Preouts, u can't go wrong. Leave the rear speakers out and just have the 2 way components up front, and later if u want it louder add rear fill. And it will save u money too. If u don't think components are the way to go then just get some coaxial speakers in the front doors. But components sound that much better IMO and more bassy up front, so that's your mid tight bass ur looking for. Later on u can deaden the doors to help stiffen them so the components mid bass sounds even better. U can keep some of the gear u have now if u want and just upgrade gear with the pay check. Add 2 amps kits to that's say $60 each thats around 1200$ total roughly. U can spend more on better quality gear but just get some decent branded middle range stuff and u can upgrade later but u can't go wrong with anything from sonic since u don't have a local store, instead of kicker etc. just my opinion. Good luck. I already have rear speakers in, but I could always move them up front once I get some brackets made. I already have the head unit, it has 3 preouts.
SQ SUBARU Posted November 5, 2013 Report Posted November 5, 2013 So, just Take it to the professionals if ur not sure. Get 6 1/2 or 5 1/4, components in the front u can find out what fits it not and get speaker spacer adapters. Have a look on bcae1.com. They have good setups diagrams etc and lots of info on the basics. Have a read here first and then plan out what u want and need to buy. Re read every post on here again there is some good advice so u can move forward. If u use an amp u need speaker wire AND RCAS to hook the speakers up. The website I posted says all that so have a read. Ipad mini as main source unit, w/ Kenwood KDC-U7056BT,Digital Designs CS6.5 2 way components, Alpine PDX-F4 4 channel & PDX-M6 mono, x1 Jbl P1224 12", single ported box @ 34hz, front doors + trunk sound deadened w/ dynamat xtreme,all knukonceptz wiring/fusing. *In progress - Audison bit ten d dsp, fully optical.
xan326 Posted November 5, 2013 Author Report Posted November 5, 2013 Take it to the professionals if ur not sure. Get 6 1/2 or 5 1/4, components in the front u can find out what fits it not and get speaker spacer adapters. Have a look on http://www.bcae1.com. They have good setups diagrams etc and lots of info on the basics. Have a read here first and then plan out what u want and need to buy. Re read every post on here again there is some good advice so u can move forward. If u use an amp u need speaker wire AND RCAS to hook the speakers up. The website I posted says all that so have a read. Lol professionals where I live, they don't exist. I'm making my own brackets for my doors once I get the original ones out do do measurements.
