Sundown X15 box input please
I figured I'm not trying to only do decaf music and want a good in between. (Don't really listen to decaf/slowed at all ha) Anyways as good as I can get with the x without sacrificing anything. So I'm open to a different tuning if you think I'll get more out of it.
I'll go run outside and take some measurements real quick.
Well that is just plain weird. Did your buddy give Ryan constraints as far as max depth, height, or width?
If limiting factors were present, he may have just done the best he could with what he had to work with. There is another possibility that the sub is so NEW and no specs were available at the time he designed the box. I only noticed JUST today, that Sundown has a screenshot of T/S specs. They weren't on the website until recently, like within the last few days-I check often.
So me personally, I'd up the port area another 20" and see what that does. I'd double baffle for sure. I would ditch the idea of doing 45s, they are not needed.
I've had the specs since around July.
TEAM SUNDOWN HAWAIIHAWAIICARAUDIO.NET
150Db Club
160Db club in the future
I see krakin as a threat
can you tell me the Xmax, Sd, and woofer displacement then?
I think you have a bit of truck stuck in your mud bro
~Ford Ranger, ext cab
Kenwood DDX470
1/0ga stinger wiring for big 3
1/0ga ofc flextech wiring
3 kinetik 800's
AQ2200 @1ohm
Sundown Audio X15
in a 27Hz tuned ported box
LE BUILD LOG!!!
  • Who's Online   0 Members, 0 Anonymous, 1537 Guests (See full list)
