gatorboy112 Posted October 31, 2013 Report Posted October 31, 2013 finishing up a basic build for my fiances set up. I haven't done an install myself in about 10 years and it's a learning process all over again. Took me two days to cut, build, carpet and put her box together but it felt much better than paying a local place 250$ for the same simple box. It's one box but I build a divider so each sub has its own airspace (1.55cubic feet each) I'm running a 4ga knukoncepts cca amp kit, to a mtx 801d rated at 800w rms at 2ohms and 400w rms at 4ohms to two dvc 4ohm kicker cvr 12s using a Pac sni-35 LOC with a LC-1 remote level controller. I have each sub wired in series to an 8ohm load going to the left and right speaker terminal on the amp which is internally wired parallel bringing it to a 4ohm load at the amp. She drives a 2012 altima 2.5s with just the basic stereo system in it and doesn't want to get an aftermarket hu. Trying to keep it on a low budget. That's why she's currently using my amp i used on and off the last 12 years. Is there anything that i should ditch or will this set up work. The only thing I was thinking is the LOC but I keep reading different and confusing things about them. Thank yall for any help.
rockFord_Expedition Posted October 31, 2013 Report Posted October 31, 2013 finishing up a basic build for my fiances set up. I haven't done an install myself in about 10 years and it's a learning process all over again. Took me two days to cut, build, carpet and put her box together but it felt much better than paying a local place 250$ for the same simple box. It's one box but I build a divider so each sub has its own airspace (1.55cubic feet each) I'm running a 4ga knukoncepts cca amp kit, to a mtx 801d rated at 800w rms at 2ohms and 400w rms at 4ohms to two dvc 4ohm kicker cvr 12s using a Pac sni-35 LOC with a LC-1 remote level controller. I have each sub wired in series to an 8ohm load going to the left and right speaker terminal on the amp which is internally wired parallel bringing it to a 4ohm load at the amp. She drives a 2012 altima 2.5s with just the basic stereo system in it and doesn't want to get an aftermarket hu. Trying to keep it on a low budget. That's why she's currently using my amp i used on and off the last 12 years. Is there anything that i should ditch or will this set up work. The only thing I was thinking is the LOC but I keep reading different and confusing things about them. Thank yall for any help. Sounds like you're wiring it right but just make sure you don't go astray thinking that those are literally left and right speaker terminals. It is a mono amp with two sets of terminals for wiring convenience. Since that amp isn't 1 ohm stable, a 4 ohm load is your best bet like you have going on. Your wiring should look like this (which it sounds like you have achieved): Edit: You can ditch the LOC like you mentioned since that amp accepts high level inputs Old School/New School RF Build March 2015 SOTM Winner How to crimp large wire
