Volt/amp meter hook up
http://www.amazon.com/Volt-Meter-Digital-Shunt-200V/dp/B005HBBZEM/ref=pd_sim_sbs_hi_4
I just got one of these in the mail. Im little skeptical bout it, only cause im not to sure on how to hook up the shunt, my brother told me its similar to a fuse. How do i go abouts on hooking this up so i can read the load of my amp? I understand the basic red/black. But then it says somewhere the shunt is hooked up to the negative terminal and then the load. Now do i take it to the positive of the load or the negative. Im just trying to be on the safe side so i dont blow an amp.
Jeep Cherokee 4dr -4.75 in front, new rusty's 4.5 in rear leafs -micky thompson 35x14.50x15 -locker rear -Rusty's offroad Engine/transmission/transfer case/crossmember/gas tank skid plates -Warn front bumper with 8000lb winch -Custom rear bumper -Warrior product tube doors (summertime) -Optima redtop (starter) -26XK miles and still runs like a bat out of hell
Kenwood H/U
1/0 wire,
136 amp alt 200 ah batteries 12.7 daily
2 Apsm 1500 @ 2 ohm strapped on zv3 d1 with ns softparts
Mb quart 125.4 wired to 4 aura 6's
3.6 cube box tuned to 36 plays down to 23hz
Here are my very simple thoughts. Don't hook it up. It will only add resistance to your system. There are other ways to check your amp draw and it's not something you have to constantly monitor.
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
i knew that, right now im only using the voltmeter side. i kept looking at it, and very skeptical about it. Not to worried about the resistance, voltage really isnt a issue since i roughly have about 300 ah in batts for 1500 watts, Guess i wont be using it then.
Kenwood H/U
1/0 wire,
  • Who's Online   0 Members, 0 Anonymous, 2010 Guests (See full list)
