97 dakota led problem
I have a 97 dakota I put led all around my corner and tail lights I put the ep27 led relay but its not working right, I have to turn on the drl for it to work right could it be when I install the relay I had the drl on to make sure I install led bulb right. here the video show what it is doing with drl off all the lights flash and my dash.the ep27 suppose to fix this but its acting crazy when drl off.
02 dodge ram 1500 reg cab 3rd gen
2 sundown sd-2 d4
soundstream rub1.2500 amp
all sky high car audio-fuse,fuse holder,wire,ring lugs and rca
flex tech
box design by Joe X
supension-mcgaughys 2in drop spindal ,western chassis 6in flip kit,buddy custom c-notch
04 5.7l hemi motor swap and made it an slt eletric everthing
youtube channel-http://www.youtube.c...43?feature=mhee
http://www.stevemeadedesigns.com/board/topic/190882-02-dodge-ram-1500-3rd-gen/
I cant see youtube videos at work, but do you have LED's in the brake bulb as well? Or is it a double filiment buld (brake and signal). I hear that even with the LED relay, you need to install a resistor (do not know what size) on the signal light side of harness. So one resistor on LF signal, one of RF signal, and that should get rid of it.
*EDIT* Search user Bassstalker. I think he was going through same issue and fixed with resistor on signal side.
If it's worth building, it's worth over building.
idk I just turn my parking light on to fix it.
2 sundown sd-2 d4
flex tech
box design by Joe X
fixed the problem
2 sundown sd-2 d4
flex tech
box design by Joe X
