charging 2 batt.
i have a 2002 pt cruiser .. i want to run 2 batts in it .. i was thinking the xs d5100 up front and a d3100 in the back .. its hard to find a new alt. for it so i was wanting to know if there was another way to keep them charged .. or if anyone had some good advice about this lol other then getting a new car ..
as for the audio gear i am running now
realm 600.4
memphis mojo 2500.1
it works good on a stock elec. but some times if the a song with a lot of bass hits it truns off on me .. i have had it like this for a year now with no other problems ..
alpine head unit (freebee 2009 model)2 sets of eclpise 5.25 comp. speakers.
1. set is in the a-pilors
1. memphis mojo 2500 watt amp
1. rockford fosgate t2 15"
dual 2 ohm wired to 4 ohm . seeing 600 watts
1. realm audio 600 watt 4ch
Go ahead and install it in the back, do the Big 3 with 1/0, do a 1/0 positive run to the back batt from the front, and find a good ground in the back for the negative.
At least once a week, just be sure to put it on a charger to make sure the batteries get topped off since your alt won't fully charge them up.
for the 2nd battery in the do i need to run wire from the alt to that one .. or just from the alt to the front battery. .. when doing the big 3 do i need to run a fuse from the alt to the battery ?
You can fuse the alt+ to battery if you want, a lot of people don't.
Do 1/0 from alt+ to front batt+
1/0 alt casing to front batt -
1/0 front batt - to frame/strut tower
1/0 front batt+ to back batt+ with a fuse at both ends by the batteries
1/0 back batt - to frame
well that sounds pretty easy . thanks for the help. I cant wait to go and do this
  • Who's Online   0 Members, 0 Anonymous, 3472 Guests (See full list)
