difference is current 18" Fi subs?
Fuzzy336
what works for you wont work for others... and its good you can do 157 those are good numbers. have you ever metered your setup with a larger box one with the proper size per sub?
im not saying it wont work just saying it could do much better in a bit bigger box
You guys an proper box who says there's a proper box ? If there was why isn't everyone loud? Who else is doing 156 from cargo area besides Meade an myself? How does Berger get a 160 out if 4-18s in a forth in a civics backseat ? Proper box? I don't think so .. Op do what u want 4-18 s can an will work just saying
The manufacturers say there is a proper range of airspace needed for OPTIMAL performance. Are you saying that none of these manufacturers know what they're talking about?
I'm saying there is no proven box design recommended means recommended dc 18 a recommend 6-8 cubes if I remember right an after long testing work best in 5 cubes an Miguel's on my power bigger would be just sloppy for me ....
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
thats the reason it is working for you.. you are giving them power.. the OP will be under powering his 18's.. if he was running 9 to 10k to the subs it would be better but he is throwing 5k on 6k worth of subs
It seems op is going to do what he wants regardless .. I gave my 2c I'm out .. Hope u all get loud ?
TEAM DC AUDIO
PREAMP:arcaudio
SUB AMP: 2-dc7.5s
BATTERIES:6-d1400s
98 I apprecieate the input don't get me wrong, but sense I'm only going to be running like 5.5kw I want to make sure I do have enough airspace, you know? I'm doing this build on minimum wage while still paying my bills so I only got one shot at this money wise
My Youtube Channel
Trying to guess the SPL of a system with out a meter is like trying to guess how much air pressure is in a compressor tank just by letting some of the air out.
...Seems like 90 psi...
  • Who's Online   0 Members, 0 Anonymous, 5740 Guests (See full list)
