Slammed Dodge Challenger Sundown/CT Sounds Build
Car is clean, too bad you're friends with brockcock.
who?
09 Challenger R/T (Audio system under construction):
  • Pioneer AVH-X4500BT (PAC RP4CH11 harness)
  • (2) Sundown Audio SA-8v2 (inverted)
  • CT Sounds AT1400.1D
  • XS Power D3400
  • 40 sq ft. Audiotechnix deadener
  • 1/0 Audiotechnix wiring
  • stock Boston Acoustic 7 speaker amplified system (for now)
  • Sealed trunk enclosure
Build log:
http://www.stevemeadedesigns.com/board/topic/178399-slammed-dodge-challenger-sundownct-sounds-build/
TEAM GOAT
Finally. It's jus a really quick one I did before I had to leave work. So sub placement may not be exactly where you want. Lmk and I can change stuff tomorrow. Add a double baffle, different style internal supports, etc.
2 - Sundown SA 8V2 | CT Sounds 1400.1 | Pioneer DEH-X8500BS | 4/0 Big 3
Well on the first box i spaced the subs so they both were as far to the right as possible so i wouldn't have the port ending in the middle of the cone of the sub on the left. i heard that might cause cancellation? also how beneficial are the 45s in the corners?
  • XS Power D3400
Build log:
TEAM GOAT
Everything I read on the sa8 v2 said you need to have the box well braced. So that's how I did my bracing. Whether it's entirely necessary for 8s? I don't know but I wasn't taking the chance for a few extra steps.
As for the sub spacing, they would be squeezed up very tightly to each other to keep them behind the port wall. I haven't heard about that before, but I'm learning about all this audio stuff as well.
so the 45s are for bracing rather than diffusing airflow?
  • XS Power D3400
Build log:
TEAM GOAT
Are you dead set on that basic box design? I think having the subs on the outsides with a center port would look pretty cool. I'll draw one up tomor at work. Haha. How much more room do you have to play with? Could the box be deeper if it had to be?
Yes they are for strength. The routed port wall and corners are to prevent port noise though. And provide a smoother path for the air to flow.
its pretty much at its maximum size and still be able to secure it to the false floor. I considered a center port but for some reason, i can't recall now, i decided on a driver side port. with one in the center it would be 2 inches down the middle then they would split off into opposite directions at 1 inch a piece if I'm not mistaken?
  • XS Power D3400
Build log:
TEAM GOAT
