Renault Megane 4 Fi sp4 18s Walled 12k -- 510 pics
Been taking less and less pictures its hard to press the button when its so cold your hands are numb.
First job today was get glovebox in which didnt fit back due to 6 runs of 0awg in its way so cut 5" off the back of it so it slides back in.
Didnt take pic but it fit first time.
Made a quick cardboard cutout for door card as i knew i wouldnt get it perfect first time.
Then cut it out on 18mm mdf.
The factory door cards was so bulky they touched the side of the seats.
I tried to make these as shallow as i could so the speakers wont be right up against them.
I planned out where i was going to have the speakers but done it roughly which is not the right way.
I kind of got lost in the grids and gave up.
Made the cutout for door release handle the factory position.
Plan is to have 8 crossovers to the left of the handle.
Its only fixed on temporary with 2 screws through the door just to make sure it open and closes properly.
I will be fixing steel angle to the door then bolting door card to that.
Looks very flat and boring at the moment but once i bring it out with crossovers and speakers it should look a bit better.
Not sure how to finish them yet.
2004 Renault Megane
Pioneer AVH-4400BT
5 XS Power D3100
2 Renault 210a Alternator
1 Hertz 15k Spl Monster
2 RF T600-4
16 RF T162s 6.5" Mids
16 RF T1T 1.1" Tweeters
4 FI SP4 18" D2 subs
Peak: 155.0 @ 31hz
40hz: 154.4
33hz: 154.6
25hz: 154.0
20hz: 152.5
Build Log: http://www.stevemeadedesigns.com/board/topic/178428-renault-megane-4-fi-sp4-18s-walled-12k-457-pics-termlab-scores/
I wanted to carry on with doorcards today but being so windy and raining i had to end up backing car half into garage to do some wiring.
Connect 8awg from subs to them then on other side 4awg to amp.
Thats about 1mm gap between bolts from positive and negative can see something bad happening here.
Temporary solution for now but guessing it will fall out so might squirt some silicone between bolts so they dont contact.
Took me about 4 hours to do 8 cables.
Just gotta put fuses on positives and connect to buss bar.
2004 Renault Megane
Pioneer AVH-4400BT
5 XS Power D3100
2 RF T600-4
Peak: 155.0 @ 31hz
40hz: 154.4
33hz: 154.6
25hz: 154.0
20hz: 152.5
  • 4 weeks later...
Its been a while since ive made some progress on my build been trying to sort out my suspension as the rear springs bottom out and ive still got 250kg to add to the back.
Anyway i thought id find a place for new voltmeter to go.
I have no real precision tools like a dremel to make a nice cutout for it so i ended up making a hole with soldering iron and using little file.
Takes ages with a little file but its almost the right size for voltmeter.
Hopefully more progress will happen soon.
2004 Renault Megane
Pioneer AVH-4400BT
5 XS Power D3100
2 RF T600-4
Peak: 155.0 @ 31hz
40hz: 154.4
33hz: 154.6
25hz: 154.0
20hz: 152.5
Another rainy day so cant get much done. Finished filling out the whole for voltmeter and test fitted, still needs wiring up.
It turns out after all my planning i mis measured.
Quick change of plan and they fit, not how i wanted but atleast they all there.
Wanted to route out all the speaker holes but would of been too messy to do indoors so just started marking a few center points.
2004 Renault Megane
Pioneer AVH-4400BT
5 XS Power D3100
2 RF T600-4
Peak: 155.0 @ 31hz
40hz: 154.4
33hz: 154.6
25hz: 154.0
20hz: 152.5
What the hell happened with the amp to make you do that?
I mean shit that amp costs way more than my 2 750.1s combined.... I'd be pissed if I had to bolt power and ground onto the rails. That's what terminals were made for
SCSB
Santa Cruz Speaker Box
Build logs:
Daily Driver Lemon Marquis
2 american bass 750.1s
350.4 on 14 focal 6.5s
sq 945 on 4 hertz tweeters
http://www.stevemead...__fromsearch__1
The Mustang 'dubbed' Shirley the project from bullet holes to badass
http://www.stevemead...cond-skin-time/
The amp comes with direct connections but only 2 positives and 2 negatives in 0awg so i wanted to double it up so now 4 positives 4 negatives.
2004 Renault Megane
Pioneer AVH-4400BT
5 XS Power D3100
2 RF T600-4
Peak: 155.0 @ 31hz
40hz: 154.4
33hz: 154.6
25hz: 154.0
20hz: 152.5
