2012 Dodge Challenger SRT-8 Audio Build
This is a SQ build I did for a friend on his 2012 Dodge Challenger SRT-8. Goals for this build is to keep much trunk space as possible but at the same time have a good level of output and sound quality. System will use OEM head unit ruining everything active.
Equipment Used: Illusion Audio C6 components in doors
Illusion Audio C12 subwoofer
Two Mosconi Gladen one Amplifiers 120.4 and 240.2
Mosconi 4to6 Processor
Oem Navigation HDD head unit
Removed the factory 3.5" speakers and replaced with the 1" Beryllium copper tweeters.
Toxic Orange 2011 HDP Dodge Challenger RT
Universial Air Suspension
22" Kartier Forged wheels
Flowmaster American Thunder Cat-back
soon to come audio build
- Ground Zero Hydrogen 30x subs
- Ground Zero Plutonium 3 way components
- singer wiring and accessories
SQ Build Logs
Facebook https://www.facebook.com/pages/Hinnant-Design/102693809895087
Moving on to treatment for the doors. focal bam xxxl and blackhole tiles used for deadening
and control sound in the doors. also the mdf speaker adapter were made and sprayed with bed liner.
Same was done to the passenger side
SQ Build Logs
sexyyyyyy
2010 Mazda 3
*Rebuild Time*
Subs - (2) AA Mayhems 12's
Sub amp - (1) Populus Audio TPA 6500
Headunit - Pioneer App Radio 2
Batteries - XS Power (1) D3100 up front | 6 XP950 rear
Wire - Sky High 1/0 Gauge wires and RCA's and steve's VM1
Alternator - Singer 260 Externally Regulated
Front Stage: (2) PRV Audio 10W650A (4) PRV Audio 8MR500-PhP-4 (4) DS Bullet Tweets | (2) 6.5 Components (Rear doors)
Mids & high Amp : (2) Populus Audio 100.4
Processor: Rockford 3sixty.3
The Build Log : http://www.stevemeadedesigns.com/board/topic/175922-2010-mazda-3-2-aa-mayhems-12-pg14-new-video/page-11
here is my dream challenger
2010 Mazda 3
*Rebuild Time*
Moving on to the trunk area. I took a mold of the oem foam spare tire area
The enclosure was test fitted back in the spare tire area in it foam tray.
Then the enclosure was wrapped in trunk liner
SQ Build Logs
Next the simple amp rack build to house the 4to6 processor and the two mosconi one amps
The fit was good to go, then amp rack cover was wrapped in trunk liner.
Here is the completed setup. He was very happy with the build and sound quality. With the oem look and feel but with the great aftermarket sound. sub had good output and blended very well with the front stage.
SQ Build Logs
Sweet looking challenger right there. I like!
Im still working on my challenger at the moment. I finished up my air ride a month ago. Hope to start on the audio build in a few weeks after
I finish up a few jobs. Here is my challenger
10da243f-3538-4c4d-9a9a-6727d67e2238_zps
SQ Build Logs
That stance… Im jealous. I thought mine looked good.
09 Challenger R/T (Audio system under construction):
  • Pioneer AVH-X4500BT (PAC RP4CH11 harness)
  • (2) Sundown Audio SA-8v2 (inverted)
  • CT Sounds AT1400.1D
  • XS Power D3400
  • 40 sq ft. Audiotechnix deadener
  • 1/0 Audiotechnix wiring
  • stock Boston Acoustic 7 speaker amplified system (for now)
  • Sealed trunk enclosure
Build log:
http://www.stevemeadedesigns.com/board/topic/178399-slammed-dodge-challenger-sundownct-sounds-build/
TEAM GOAT
looks fucking sick yoaaa what air ride system you got?
2010 Mazda 3
*Rebuild Time*
