Honda accord sedan v6 Stealth build
Very nice work! Would have preferred to see a small battery instead of a cap but the install is looking awesome so far.
My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee
My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37
My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/
2016 Mazda 6 Touring
JL Fix 86 - OEM signal correction
B2 prototype DSP 6to8
B2 Ref63 - 3 way active set
2 B2 Class H quattro's
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
B2 SLIP40 - Lithium in the trunk
Northstar Group 35 under the hood
100ft 2/0 welding cable
30ft 4ga welding cable
20ft 8ga welding cable
All stinger OFC speaker wire
Soundrive custom RCA's
Tons of attention to detail.... Can it be perfect?
Moving onto the main panel cover for the system.
Next I made grills to cover the sub and amp when hauling in the trunk area.
Toxic Orange 2011 HDP Dodge Challenger RT
Universial Air Suspension
22" Kartier Forged wheels
Flowmaster American Thunder Cat-back
soon to come audio build
- Ground Zero Hydrogen 30x subs
- Ground Zero Plutonium 3 way components
- singer wiring and accessories
SQ Build Logs
Facebook https://www.facebook.com/pages/Hinnant-Design/102693809895087
SQ Build Logs
Grill covers wrapped in trunk liner.
Then the enclosure and amp rack cover is wrapped in black vinyl.
SQ Build Logs
The main trim panel was wrapped in trunk liner carpet.
Now you see me!
Now you don't!
This build came out very nice, as you can see he has much more trunk space. While keeping the same amount of audio equipment. The system sounds better then before, the sub output seems higher. I added some blackhole stuff, made by orca design on the inside the enclosure.
SQ Build Logs
I was able to get this build done in a short amount of time, 2 business days. He was amazed when he picked up the car that it came out so well.
SQ Build Logs
I am very impressed!
2012 Silverado ext cab
Kenwood DDX470
XS D3400 (starter)
XS D375 (under passenger seat)
XS d3100
Mechman 240
Big three
SMD VM-1
All SHCA wire
80 sq feet of Damplifier
6.5 Crescendo CZ's (front doors) (needed)
5..25 Crescendo CZ's (back door) (needed)
Crescendo 125.4 (needed)
Sundown Zv4 12
Skar 4500 (2ohm)
I absolutely love how well those grill covers blend in when installed.
2000 Toyota Camry With Sealed Off Trunk
Sky High OFC Wiring
DC Power 270 XP Alt
AQ 2200 Sub Amp
Two DC Level 4 m2 12s
80 Mil Murdetmat
Gathering Parts For Wall Build.
Team DC Audio 2014 Member
He didn't want to add any more equipment or switch anything out. He just want more room with the same sound he had before.
SQ Build Logs
My goal on builds is trying to keep everything functional and stealth. I enjoy building these setups the most.
SQ Build Logs
