96 4Runner with 2 Fi Q 18s (lots of pics)
I've done my fair share.
I recommend it if you have easy access to propane filling.
I have 11 tanks, and a fill station 0.6 miles from my house.
If I fill all at once, they usually charge around $80
I measured around 15-20MPG (on LPG) on 38.5s
I later built a dual tank setup for it, but it went to smaller, cut tires, so it doesn't see road miles
I say do it, it just looks so cool, and is so much cheaper/easier
Yes I have a lot of stereo weight. I build for Smiles Per Gallon not Miles Per Gallon LOLZ
My build - 1996 4Runner with 2 18s - 149+ in a sealed box (with radiators)
0a4ee87c-28c8-4bf8-9dfe-5a06b9dea2dc_zps
3e3eb9dd-70f8-4424-ad11-ccebcd929ac4_zps
love those yotas! liked the tubed bumper look on the 4runner, excited to see how it comes out! and if you ever work on that pickup, post pics!
~ If it was easy, everybody would be doing it ~
Oh yeah there was definitely room for more wire. I could make any battery fit up front. But I bought the 5100 to initially replace the dead stock one as a direct replacement. I just didn't put it in until I started the build. And at that point I didn't plan on needing that much battery. Then I added two 680s. Then a 3100. Then 2 more haha
I think 6 batteries should suffice.
What did you have that needed four runs of power?
What do you want to see?
That's the coolest project I have ever done. Everything prior was a "bolt on" build. Or I had experience. I've been building computers and wiring buildings professionally since I've been 7, so wiring in a car is simple. Adding bolt ons is simple. That truck has been an awesome challenge. Made almost every piece I needed
Completely built the motor. First time ever
Built the trans and transfer cases.
It's a dual transfer case with an independent shift triple stick setup and drivetrain caliper brake
