sbg Posted November 15, 2013 Report Posted November 15, 2013 So I'm at the point to put wire in.(power,ground,rca) when I look under the hood I see this. And would like to know what u guys would do. Not sure we're to wire at, or if I should use ring terminal or what. Crazy 150 amp fuse on the battery terminal to. 01 focus se 110 amp alt Big 3 sky high and stinger hpm ofc 1/0 Super start platinum AGM (starting) 2 runs of 1/0 Execution audio front to back Kenwood double DIN DDx271 A pillars- orion 4" super tweeter and 2-1" alpines. Orion xtx 64 in the front doors 2:1 4th order bandpass Sealed off trunk Digital designs deadener on roof/ rear deck Orion hcca 12s (black coils) Orion xtr3700.1 Orion xtr250.2 mid/highs All sky high 1/0 in trunk dual runs(power/ground) Sky high dual 1/0 inputs 2 xs power D3100 in back Sky high batt blocks Rose audio batt blocks Stinger volt meter All sky high 1\0 fuse and holders Db link remote/ rca
sbg Posted November 15, 2013 Author Report Posted November 15, 2013 1st bolt ,2nd bolt, 3bolt? Kinda scared to fuck around with that fuse. 01 focus se 110 amp alt Big 3 sky high and stinger hpm ofc 1/0 Super start platinum AGM (starting) 2 runs of 1/0 Execution audio front to back Kenwood double DIN DDx271 A pillars- orion 4" super tweeter and 2-1" alpines. Orion xtx 64 in the front doors 2:1 4th order bandpass Sealed off trunk Digital designs deadener on roof/ rear deck Orion hcca 12s (black coils) Orion xtr3700.1 Orion xtr250.2 mid/highs All sky high 1/0 in trunk dual runs(power/ground) Sky high dual 1/0 inputs 2 xs power D3100 in back Sky high batt blocks Rose audio batt blocks Stinger volt meter All sky high 1\0 fuse and holders Db link remote/ rca
graham0599 Posted November 15, 2013 Report Posted November 15, 2013 I'd say ring terminal on the bolt closer to the terminal. Only down fall is you wont be able to use that cover. Other option, buy/make a battery terminal like to where you can pull that factory part off and mount to one of the bolts My 350z build- http://www.stevemeadedesigns.com/board/topic/174424-2008-350z-build/page-2?hl=%2B350z+%2Bbuild#entry2605678
agf144 Posted November 15, 2013 Report Posted November 15, 2013 i would use the bolt closest to the right side of the pic Chick took 3 shots of Jager, and then, pissed in my mouth.. oh.. wait.. naw.. that wasnt weird.. He probably tearin dat ass up every night. Reason for "insomnia" Ain't sleeping cause he's like a horny hamster on coke. 2000 grand prix gtp: SOLD My Home Theater Build (working progress) 2002 accord coupe subs: 2 soundqubed hds300 12s 4'1" towers tuned to 29hz sub: AQ hdc3 12 Amp: pioneer gm9061 amp: poineer gm9601 headunit: kenwood kdc 255u mids: SQ pro mids midbass: polk db 8s highs: stock mids/highs: shitty off brand
sbg Posted November 15, 2013 Author Report Posted November 15, 2013 I'd say ring terminal on the bolt closer to the terminal. Only down fall is you wont be able to use that cover. Other option, buy/make a battery terminal like to where you can pull that factory part off and mount to one of the bolts . Only thing is, that both u can see sit's at a angel so the ring terminal u sit funny. But I am going to try and cut the cover so it can still be on. 01 focus se 110 amp alt Big 3 sky high and stinger hpm ofc 1/0 Super start platinum AGM (starting) 2 runs of 1/0 Execution audio front to back Kenwood double DIN DDx271 A pillars- orion 4" super tweeter and 2-1" alpines. Orion xtx 64 in the front doors 2:1 4th order bandpass Sealed off trunk Digital designs deadener on roof/ rear deck Orion hcca 12s (black coils) Orion xtr3700.1 Orion xtr250.2 mid/highs All sky high 1/0 in trunk dual runs(power/ground) Sky high dual 1/0 inputs 2 xs power D3100 in back Sky high batt blocks Rose audio batt blocks Stinger volt meter All sky high 1\0 fuse and holders Db link remote/ rca
agf144 Posted November 15, 2013 Report Posted November 15, 2013 I'd say ring terminal on the bolt closer to the terminal. Only down fall is you wont be able to use that cover. Other option, buy/make a battery terminal like to where you can pull that factory part off and mount to one of the bolts .Only thing is, that both u can see sit's at a angel so the ring terminal u sit funny. But I am going to try and cut the cover so it can still be on. the use the middle bolt Chick took 3 shots of Jager, and then, pissed in my mouth.. oh.. wait.. naw.. that wasnt weird.. He probably tearin dat ass up every night. Reason for "insomnia" Ain't sleeping cause he's like a horny hamster on coke. 2000 grand prix gtp: SOLD My Home Theater Build (working progress) 2002 accord coupe subs: 2 soundqubed hds300 12s 4'1" towers tuned to 29hz sub: AQ hdc3 12 Amp: pioneer gm9061 amp: poineer gm9601 headunit: kenwood kdc 255u mids: SQ pro mids midbass: polk db 8s highs: stock mids/highs: shitty off brand
graham0599 Posted November 15, 2013 Report Posted November 15, 2013 On just flip that block. So the hole is on the right side. The long side of the terminal would be parallel with the batt and connections could "hang" off side closer to the motor. If that makes sense haha My 350z build- http://www.stevemeadedesigns.com/board/topic/174424-2008-350z-build/page-2?hl=%2B350z+%2Bbuild#entry2605678
sbg Posted November 15, 2013 Author Report Posted November 15, 2013 I had this I wanted to use but I don't think I can. 01 focus se 110 amp alt Big 3 sky high and stinger hpm ofc 1/0 Super start platinum AGM (starting) 2 runs of 1/0 Execution audio front to back Kenwood double DIN DDx271 A pillars- orion 4" super tweeter and 2-1" alpines. Orion xtx 64 in the front doors 2:1 4th order bandpass Sealed off trunk Digital designs deadener on roof/ rear deck Orion hcca 12s (black coils) Orion xtr3700.1 Orion xtr250.2 mid/highs All sky high 1/0 in trunk dual runs(power/ground) Sky high dual 1/0 inputs 2 xs power D3100 in back Sky high batt blocks Rose audio batt blocks Stinger volt meter All sky high 1\0 fuse and holders Db link remote/ rca
graham0599 Posted November 15, 2013 Report Posted November 15, 2013 That factory connector comes apart at the middle nut just like Kinda hard to see but i used the same type of terminals on pos an neg. I mounted the factory part on the top position My 350z build- http://www.stevemeadedesigns.com/board/topic/174424-2008-350z-build/page-2?hl=%2B350z+%2Bbuild#entry2605678
sbg Posted November 15, 2013 Author Report Posted November 15, 2013 On just flip that block. So the hole is on the right side. The long side of the terminal would be parallel with the batt and connections could "hang" off side closer to the motor. If that makes sense haha I don't think u can do that. There is 3 like 5 ga wires going in to the side of the block u can't see. To short to more to the other side if I was to turn it. 01 focus se 110 amp alt Big 3 sky high and stinger hpm ofc 1/0 Super start platinum AGM (starting) 2 runs of 1/0 Execution audio front to back Kenwood double DIN DDx271 A pillars- orion 4" super tweeter and 2-1" alpines. Orion xtx 64 in the front doors 2:1 4th order bandpass Sealed off trunk Digital designs deadener on roof/ rear deck Orion hcca 12s (black coils) Orion xtr3700.1 Orion xtr250.2 mid/highs All sky high 1/0 in trunk dual runs(power/ground) Sky high dual 1/0 inputs 2 xs power D3100 in back Sky high batt blocks Rose audio batt blocks Stinger volt meter All sky high 1\0 fuse and holders Db link remote/ rca
