Need Help Fixing My Memphis Amp
blake1886
So i have recently got a Memphis 16-MCD1000 amp from a friend. it was just laying around his house and he didnt have a use for it and wasnt even sure if it worked because it was his brother. I tried to plug it into power to see if it works, but it goes directly into protection mode. I'm not a major expert with amplifiers but i do have some electronic background and i am a quick learner with electronics. I couldn't see any physical problems when i looked at the board, no caps were broken and no connections were fried. Can anyone help me with this amp? I'd really like to get this going. Thanks!
1278296_10200353087139336_2054241885_n.j
-2004 Ford explorer
-Pioneer Deh-80prs HU
-4 Rockford Fosgate R1683
-2 Rockford Fosgate P1S4-12 wired to 2ohms
-1 Rockford Fosgate Prime R500-1
-I know it's very basic...
Can you get some gut/internal pictures. Others will be able to help then
'01 Dodge Stratass Sealed Trunk Build Log
2008 Honda Fit Sport Build Log
On 10/3/2013 at 10:00 AM, ROLEXrifleman said:
Anyone who says they knew everything they wanted out of life at 19 can go suck a bag of dicks cause they are lying to themselves or brought up in a cult.
sory, not the best pictures but i cant get a better one at the moment.
-2004 Ford explorer
Have you checked the RCA connections not going to ground? Check the Mosfets running down the sides for burn marks loose from heatsink. Good Luck!!
Pioneer P99RS
Ampere 3800
2-Ampere 125/4
4-6.5 inch Hertz HSK XL Mids
2-5.25 Satori Mids
2-Hertz Silk tweeters
DC Audio Level 5/12
Skyhigh Wire
Mechman 320
XS Power D3100
can you explain a little bit more please? Like i said, im not really an expert
-2004 Ford explorer
Take a close look at the joints where the power connectors, speaker connectors, and RCA's are fused to the board.
Usually these are soldered at a 90deg to the board and pressure on them can cause them to crack as they flex.
This would be the first place I check for cracks in the solder, a connector that has lifted/delaminated off the board, or even sometimes they corrode.
Closeups of the internal portion of the connectors will help, you can sometimes find a loose one just by touching it.
I'll try to check some of these things when I get home from school tonight.
-2004 Ford explorer
And if you want a close up of certain parts just let me know where you want more pictures
-2004 Ford explorer
Before when i waa testing the amp i hqd it plugged into an old power supply from a computer, i realized the power supple would stop once i switched it on so i decided to hook it up to an actual car battery. After plugging it into a crappy speaker laying around I figured out that when the speaker amp is plugged in the protection light flashes and the speaker makes a clicking noise repededly. Idk if this help at all but I thought it could be of importance. And it also did not blow the fuses in the amp.
-2004 Ford explorer
  • Who's Online   0 Members, 0 Anonymous, 671 Guests (See full list)
