Miguels Posted November 23, 2013 Report Share Posted November 23, 2013 the dmm can be off.. touch the leads together and see what it reads my logshttp://www.stevemead...-my-new-set-up/my blow through loghttp://www.stevemead...future-updates/ 96 ss http://www.stevemeadedesigns.com/board/topic/164094-96-impala-ss-build/ Link to comment Share on other sites More sharing options...
Afficionado Posted November 23, 2013 Author Report Share Posted November 23, 2013 the dmm can be off.. touch the leads together and see what it reads Reads 0.4 If you have any questions relating to nutrition, lifting, or health in general, feel free to give me a PM and I will give you straight forward advice with no BS involved. Link to comment Share on other sites More sharing options...
Miguels Posted November 23, 2013 Report Share Posted November 23, 2013 when you touch the dmm leads together not with the sub.. i would just wire each coil to its own output and see what it does.. the amp will bridge it internally and it will still see a 1 ohm load my logshttp://www.stevemead...-my-new-set-up/my blow through loghttp://www.stevemead...future-updates/ 96 ss http://www.stevemeadedesigns.com/board/topic/164094-96-impala-ss-build/ Link to comment Share on other sites More sharing options...
Afficionado Posted November 23, 2013 Author Report Share Posted November 23, 2013 when you touch the dmm leads together not with the sub.. i would just wire each coil to its own output and see what it does.. the amp will bridge it internally and it will still see a 1 ohm load This is what it reads when I touch the leads together. 0.4. And ok, I might do that. If you have any questions relating to nutrition, lifting, or health in general, feel free to give me a PM and I will give you straight forward advice with no BS involved. Link to comment Share on other sites More sharing options...
Afficionado Posted November 24, 2013 Author Report Share Posted November 24, 2013 Also check the ground of the amp..having enough voltage and not enough ground will hinder output..maybe 1 coil is loose or came off or maybe the rcas need to be replaced..gotta measure that impedance of the sub make sure it is still connected..getting stinky is something sundowns do. Ive heard alotta ppl saying they start stinking with tuning.. also..wats the airspace of the box after displacement? it's a big box, around 3 cubes. any ideas? If you have any questions relating to nutrition, lifting, or health in general, feel free to give me a PM and I will give you straight forward advice with no BS involved. Link to comment Share on other sites More sharing options...
nCOMP1337 Posted November 24, 2013 Report Share Posted November 24, 2013 id try a better dmm, it should read like .9-1 since they are a dual 2 sub. I dont see how youd have it reading .4, it would have to be a dual 1 sub to read that low wired in parallel I would think. dmm could be off as you stated, it is not a good dmm. But still doesnt seem to suggest why the output isnt there. Do you have a gain control knob connected to the amp, and maybe thats turned down? All fuses, wiring, connections, all good? sorry if someone already stated that. Link to comment Share on other sites More sharing options...
Afficionado Posted November 24, 2013 Author Report Share Posted November 24, 2013 id try a better dmm, it should read like .9-1 since they are a dual 2 sub. I dont see how youd have it reading .4, it would have to be a dual 1 sub to read that low wired in parallel I would think. dmm could be off as you stated, it is not a good dmm. But still doesnt seem to suggest why the output isnt there. Do you have a gain control knob connected to the amp, and maybe thats turned down? All fuses, wiring, connections, all good? sorry if someone already stated that. Gain control was all the way up. All connections are solid. RCA's do need to be replaced. If you have any questions relating to nutrition, lifting, or health in general, feel free to give me a PM and I will give you straight forward advice with no BS involved. Link to comment Share on other sites More sharing options...
Jessica Posted November 24, 2013 Report Share Posted November 24, 2013 Hook up one coil. Then unhook it and hook up the other. They should gave pretty much the same output. You don't need to Wang on it just moderate volume. I'm thinking you one coil wired backward. That's what I meant by out of phase. If they bith have the same output, hook up both and see if it drops off. Then if it does switch pos/neg on one and see what it does Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13 Link to comment Share on other sites More sharing options...
Afficionado Posted November 24, 2013 Author Report Share Posted November 24, 2013 Hook up one coil. Then unhook it and hook up the other. They should gave pretty much the same output. You don't need to Wang on it just moderate volume. I'm thinking you one coil wired backward. That's what I meant by out of phase. If they bith have the same output, hook up both and see if it drops off. Then if it does switch pos/neg on one and see what it does the coils are hooked up correctly. =/ could it be that somehow is just making my signal distort really early? and i don't know if this means anything, but in my old car my HU distorted at volume 38, and now it shows distortion at 33. If you have any questions relating to nutrition, lifting, or health in general, feel free to give me a PM and I will give you straight forward advice with no BS involved. Link to comment Share on other sites More sharing options...
Jessica Posted November 24, 2013 Report Share Posted November 24, 2013 Well if you are sure about the coils then I am stumped Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13 Link to comment Share on other sites More sharing options...
