treo98cam Posted November 24, 2013 Report Posted November 24, 2013 hi everyone, im planing to seal off my trunk with 2 12s and 6k(2 saz 3k) my goal is to tune to 30hz or 35hz for daily depending on how much output if lose tuning to 30hz. this is gonna be with a 8in aeroport. for my spl im planning to use a 10in aero port and tuning to 40-45hz depending on the subs and how my cabin reacts to the subs. first question is if i build a box that is 4.8cuft net will that be a good size? the box will always stay 4.8cuft net due to inverting my subs and only placing enough of the port interal to keep it at 4.8cuft. The car this setup will be going in a 98 toyota camry. atm i will be using 2 treo ssx rebult by a friend. however in the future i plan to run ssa Zcons. but i am still open to suggestions. second question is, should i seal off my trunk with the box all the way up to the backseat opening or..... push it all the way back. if i push th box all the way back i will have around 15in to act as a tunnel. this will be my first time sealing off so i am open to suggestions. I compete in meca so the meter is placed on the headrest. thank for the help in advance and if any further questions i will answer to the best of my ablities.
Jeremy Perfect Posted November 24, 2013 Report Posted November 24, 2013 Sounds a little big for 2 12s. Most of the 12s I've seen only need 1.5 for one or 3.5 for 2. So maybe 4for the port with subs ass out.
SlamminBeats Posted November 24, 2013 Report Posted November 24, 2013 4.8 isn't that big IMO To seal build a collar around box and foam wood to metal Then trim off I'm on mobile can explain better later
treo98cam Posted November 24, 2013 Author Report Posted November 24, 2013 in the future i plan to run ssa Zcons. Those Zcons like huge boxes with a 3.0cu ft mininum per sub If you can only fit 4.8 in you car, you might want to reconsider your plans for 2 zcon 12" well i can make the box bigger. i got plenty room for 2 12s. how big of a box would you guys recommend for the zcons? my team mates suggested the Zv4s also. and they said the Zv4 would need a huge box too. so i might as well make the box BIG.
slowfkncar Posted November 24, 2013 Report Posted November 24, 2013 Your plans for 45hz spl pretty much gets thrown out the window with a zv.4 ,they get nasty down low though
treo98cam Posted November 24, 2013 Author Report Posted November 24, 2013 Your plans for 45hz spl pretty much gets thrown out the window with a zv.4 ,they get nasty down low though that was my thoughts lol thats why i was thinking the zcons. but if i dont care about numbers and only plan to tune to the lower 30s then the Zv4s would be perfect.
treo98cam Posted November 25, 2013 Author Report Posted November 25, 2013 would 5.2net be enough for zcons on 6k?
SlamminBeats Posted November 26, 2013 Report Posted November 26, 2013 would 5.2net be enough for zcons on 6k? nobody really knows that answer man. youre gonna have to test. 5.1 might be enough...who knows
