Desousa93
the site also says 600 rms.. but people over power them.. i dont wanna build a box then put 1000 rms to the subs and then blow them..
:domodance: :domodance::morepower1:New Build in the Making :morepower1: :domodance: :domodance:
1999 Infiniti I30 Limited
if you break a rule and argue with n8 your going to get banned. suspended if your lucky.
Too much airspace you will lose mechanical control. Too much power you get the sub got hot. Basically you're doing two things the wrong way.
I'd go with a regular slot port, no slanted angle on the box.
H-17" W-39" D-20"
2 common walls, port between the subs facing the rear of the vehicle
Port- H-14.75" W-5" D-28"
1 extra baffle
Tuning ~35Hz Net volume 4.3 cubic feet and 73" of port(the proper amount of port area)
H-17" W-39" D-20"
1 extra baffle
So a box built this way would be okay to power each sub 1000 rms?
That's a big box, probably WAY too big for 1000W per sub.
i redited it now heres the new so far..
port area per foot needs to be more( just saying this because when I built my box I didn't have enough and I get port noise and don't want to see you make the mistake I did)
  • Who's Online   1 Member, 0 Anonymous, 1360 Guests (See full list)
