Desousa93 Posted November 24, 2013 Author Report Posted November 24, 2013 the site also says 600 rms.. but people over power them.. i dont wanna build a box then put 1000 rms to the subs and then blow them.. New Build in the Making 1999 Infiniti I30 Limited if you break a rule and argue with n8 your going to get banned. suspended if your lucky.
CleanSierra Posted November 24, 2013 Report Posted November 24, 2013 That's a big box, probably WAY too big for 1000W per sub. Im not the one you want to try to troll. Just a fyi for you.
Desousa93 Posted November 24, 2013 Author Report Posted November 24, 2013 site says 35 true.. i just want them to sound good hit lows but still have some punch to them. New Build in the Making 1999 Infiniti I30 Limited if you break a rule and argue with n8 your going to get banned. suspended if your lucky.
Desousa93 Posted November 24, 2013 Author Report Posted November 24, 2013 That's a big box, probably WAY too big for 1000W per sub. i redited it now heres the new so far.. New Build in the Making 1999 Infiniti I30 Limited if you break a rule and argue with n8 your going to get banned. suspended if your lucky.
CleanSierra Posted November 24, 2013 Report Posted November 24, 2013 Too much airspace you will lose mechanical control. Too much power you get the sub got hot. Basically you're doing two things the wrong way. I'd go with a regular slot port, no slanted angle on the box. H-17" W-39" D-20" 2 common walls, port between the subs facing the rear of the vehicle Port- H-14.75" W-5" D-28" 1 extra baffle Tuning ~35Hz Net volume 4.3 cubic feet and 73" of port(the proper amount of port area) Im not the one you want to try to troll. Just a fyi for you.
Jessica Posted November 24, 2013 Report Posted November 24, 2013 For some reason sundown told me 2.2 to 2.8 per sa12. Seriously Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13
Desousa93 Posted November 25, 2013 Author Report Posted November 25, 2013 Too much airspace you will lose mechanical control. Too much power you get the sub got hot. Basically you're doing two things the wrong way. I'd go with a regular slot port, no slanted angle on the box. H-17" W-39" D-20" 2 common walls, port between the subs facing the rear of the vehicle Port- H-14.75" W-5" D-28" 1 extra baffle Tuning ~35Hz Net volume 4.3 cubic feet and 73" of port(the proper amount of port area) So a box built this way would be okay to power each sub 1000 rms? New Build in the Making 1999 Infiniti I30 Limited if you break a rule and argue with n8 your going to get banned. suspended if your lucky.
Cameronmyers74 Posted November 25, 2013 Report Posted November 25, 2013 That's a big box, probably WAY too big for 1000W per sub. i redited it now heres the new so far.. port area per foot needs to be more( just saying this because when I built my box I didn't have enough and I get port noise and don't want to see you make the mistake I did)
Joe X Posted November 25, 2013 Report Posted November 25, 2013 So here's a suggestion, subs will take 1K each, use your amp subsonic filter to 28Hz: Port parts are as follows: 2 x Front to Back: 17 3/8" x 13 3/4"2 x Extension: 2 11/16" x 13 3/4" If you want to do 45s here's how to do them:
