Amp output issues
rolltide0323
Turn off all loudness features, and sub level to the max postion to get the most voltage from HU. Make sure you have set crossover freq correct. No way you should hace amp gain all the way up. If your head unit is 4v pre out, your looking at the gain being around 1/4 turned up or the 9;30 position. If HU is 2v preout, amps gain around the 12o'clock position. If your still not getting desired bass from subs, on the HU you may have to adjust the bass setting.
truthsayer
Yeah, i know i'm not suppose to have the gain that high but I left it there after i was finish fooling with it. I was only playing it for about 2 minutes or so.
yes pics will be better
or
This is how i have the subs wired. This was the same configuration i had before in my old truck.
which one the 1st or 2nd pic
02 dodge ram 1500 reg cab 3rd gen
2 sundown sd-2 d4
soundstream rub1.2500 amp
all sky high car audio-fuse,fuse holder,wire,ring lugs and rca
flex tech
box design by Joe X
supension-mcgaughys 2in drop spindal ,western chassis 6in flip kit,buddy custom c-notch
04 5.7l hemi motor swap and made it an slt eletric everthing
youtube channel-http://www.youtube.c...43?feature=mhee
http://www.stevemeadedesigns.com/board/topic/190882-02-dodge-ram-1500-3rd-gen/
or
Like the 1st pic. Although right now instead of connecting the 2 subs into each other they are connected to each other at the amp if this matters at all.
no it doesn't matter
2 sundown sd-2 d4
flex tech
box design by Joe X
my Kenwood had to have the sub level at +15 in order to get full clean voltage at volume 33 when hooked up to my oscope. it's not a boost for kenwoods
That's what i'm beginning to think. I had just a cheap pioneer in my other truck with no problems.
put your old radio in just to see if it changes but more likely its the hu.I have a pioneer set every thing to 0 and the amp turn 1/4 way up it my subs slams.
2 sundown sd-2 d4
flex tech
box design by Joe X
  • Who's Online   0 Members, 0 Anonymous, 671 Guests (See full list)
