*sticky* Free Tech support
plenty for 2-12's
okay thanks, you will most likly have a box request coming in the next couple of days if you are still accepting them that is
i think your score could improve with more vent area.. you have roughly 12 per cuft now.
I would try 15sqin per cuft
That's the problem, I don't really have any more room to increase port area. I think I'm pretty limited with having a small trunk, it's very tight with everything in there. I appreciate the suggestions and I'm open to others if you think it might help.
Team That Hertz2001 MustangPioneer AVIC D32 DD3512's superchargedDD M3AJL VR 6 1/2 comps and TR 5x7 coaxJL 300/4Mechman 270 amp altXS Power D3400 under hoodXS Power D3100 in trunkTL MECA score: 144.4 @ 37hz at the headrest with the trunk open
Shink the box to 4 after with 16 per
The one thing I don't want to do right now is change the box. I just got this stuff in a couple months ago and the box is screwed in. I might have to try that a little later down the road. I had a feeling I was gonna have to do stuff like this that I don't want to do at the moment. Once again, thanks for the suggestions.
Clarify this for me Ray. If I'm strapped at .7 my amps see .35. So when I clamped it my rise was to 2ohms so is that split in half? Is each amp at 1 ohm. And is starting ohm is .35 or .7
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
Would running a sub inverted effect the box tuning on a 4th order? You designed be a ported enclosure, but I was thinking about a 4th order and running the sub inverted to not disturb the sealed chamber, plus youd be able to see the chrome motor throught the port opening, kinda give it a style!
Pioneer AVH480
Zapco ST5XII amplifier
Stevens Audio 6.5" components (passive)
Onyx Subwoofer
Sky High OFC wiring
It does yes. But so little that it doesnt matter at all.
No need to worry about it
Ok cool, cause the sealed enclosures for.these subs is a max of 1.25cu ft. so I would use the same size enclosure you designed, but with the loading wall! To be right around a 2:1 ratio!
Pioneer AVH480
Onyx Subwoofer
Sky High OFC wiring
For a 12??
Id do .9 sealed and 2.3 ported
