*sticky* Free Tech support
Orange/wht to orng/wht
Cap off all others
Not needed
Alright thanks ray
Oh yea one more thing. With the relay The two grounds on pin 87 and 85 is that seperate made grounds that you make or is that grounds from both of the headunit harness and harness adapter
You know how you avoid that? Man the fuck up and bang her best friend sister mom cousin worst enemy and never look back.
JUST SAY ANTI-AUDIOPIPE
Seperate ground.
But couldn't i ground it all to one good ground? like one bolt in the dash?
Yes you can.
Speaker wires are normal.
As for p brake
Need a relay
Lt green goes to pin 30
Pin 85 & 87 go to ground
Pin 86 goes to rem turn on off the deck.
Thats it
I truely am sincerely sorry for my idiot questions
But Whats the remote turn off on the deck? for my last install i used the ignition wire/ switched (red) hooked to the other red on the harness. I thought that was the remote turn on for the deck?
I dont see anyother wire that would be the remote turn off on deck. and the dark blue is the remote turn on for the Headunit amplifier.
Blue with white.
Remote turn on.
Has a blue sticker on it that says rem.
Blue with white.
Remote turn on.
Alright i see that. Its the same as my pioneer DEH8300. But when i installed that it gave me NO power i tested it cuz i tried to use it for my Remote for my amp and it wouldnt work. So i capped it. Sticker as in The end is taped off and says system remote? thats the only blue and white wire
Yes that one.
And 500th post ftw..
alright and i hope this one recieves power cuz the one on my last one didnt... i should have it from here and if i have anyother questions i will be sure to blow this up :D not literally
