x8500bhs custom background
KMS
I've loaded images on my usb, went into the theme, background and the custom? selection icon is grayed out. I can't even see the image file names through the usb selection neither. The files are jpeg. They're saved to the root drive, not in any folder. Would this be why I can't see them?
Alpine PDX-V9
Morel Tempo 6
Alpine SBR-S8-4
Alpine CDE 149BT
i know on the pioneer 4500 you have to use micro sd card, does not work with usb, so it could be same with yours.
Hmm, my unit only has a standard older SD slot IIRC. I don't have a converter for the microsd card, nor do I have a converter for microsd to usb neither. D:
Alpine PDX-V9
Morel Tempo 6
Alpine SBR-S8-4
Alpine CDE 149BT
I have the x3500bhs been also tryin to find out how to do this..
01 focus se
110 amp alt
Big 3 sky high and stinger hpm ofc 1/0
Super start platinum AGM (starting)
2 runs of 1/0 Execution audio front to back
Kenwood double DIN DDx271
A pillars- orion 4" super tweeter and 2-1" alpines.
Orion xtx 64 in the front doors
2:1 4th order bandpass
Sealed off trunk
Digital designs deadener on roof/ rear deck
Orion hcca 12s (black coils)
Orion xtr3700.1
Orion xtr250.2 mid/highs
All sky high 1/0 in trunk dual runs(power/ground)
Sky high dual 1/0 inputs
2 xs power D3100 in back
Sky high batt blocks
Rose audio batt blocks
Stinger volt meter
All sky high 1\0 fuse and holders
Db link remote/ rca
My unit does not even have sd slot, but you still have the option to put custom background.
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
I have the x3500bhs. Load the image to USB drive/ flash drive as JPEG, Connect USB to head unit, select USB as source, when the slide show begins and you see the pic you want press the icon with a folder and an arrow. Then it says save, hit yes. Now go to the setting and backgrounds and slide over to the pic of the camera and select it.
2003 Tahoe
dc 7.5k
dc level 5 15's (3)
MMats 341's
xs power batts
lots of sky high cable
dual alts(came off the sky-high gmc and don't know who made them)
ipad in center console
vu-din in center console
all being ripped out and being sold
Going to try now. Brb
Alpine PDX-V9
Morel Tempo 6
Alpine SBR-S8-4
Alpine CDE 149BT
I will try when I get off work, kms post pic if works :$
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
Says something about can't view photos while driving. It's bypassed tho so idk...
Alpine PDX-V9
Morel Tempo 6
Alpine SBR-S8-4
Alpine CDE 149BT
Should work on mine :)
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
  • Who's Online   0 Members, 0 Anonymous, 999 Guests (See full list)
