Electrical Problem!!!???
Yes you can. Should you? No.
What should have been done was get the proper size battery for your location so that the stock wiring would reach.
OR
Just go ahead and do the big 3 upgrade, assuming that you make a new run to the fuse/relay center if needed. And then tape up any raw ends and zip tie them so they aren't loose in the engine bay. If they weren't able to be removed.
x2 on what Kranny said. I want to see what is under that shrink wrap. Oh well.
  • Who's Online   1 Member, 0 Anonymous, 749 Guests (See full list)
