Matthew S Pierce Posted December 6, 2013 Report Posted December 6, 2013 You should build a labyrinth sub box design
kiko Posted December 6, 2013 Author Report Posted December 6, 2013 You should build a labyrinth sub box design had to Google search that... lol noob i know.. if someone has cuting specs to one that works real well with the 2x e8v3 then i would definitely take it under consideration. THanks for the suggestion mattew! =D
Joe X Posted December 6, 2013 Report Posted December 6, 2013 Here's a little fix I made to make it look more balanced and will work just as well: Anyways the labyrinth variant has been designed, posted and built on this forum a while back so you may want to take a look at it, the T shaped version is the dual sub design suggestion posted at Sundown's site, so all of them are available for you to consider.
kiko Posted December 6, 2013 Author Report Posted December 6, 2013 Here's a little fix I made to make it look more balanced and will work just as well: Anyways the labyrinth variant has been designed, posted and built on this forum a while back so you may want to take a look at it, the T shaped version is the dual sub design suggestion posted at Sundown's site, so all of them are available for you to consider. design not showing.
Joe X Posted December 6, 2013 Report Posted December 6, 2013 design not showing. It's the exact same cutsheet as the one I left you before, I just moved the sub holes to the center, which will not hurt the box performance at all. You just don't want a sub too near to the inner end of the port like if you placed one on the far right. The username of the guy who built the labyrinth design is IanJohnson if you want to look into it.
VaNQuisH Posted December 6, 2013 Report Posted December 6, 2013 ported in the low 30's is highly suggested with proper airspace and port area you'll be very very happy! 32-35hz Currently: * Hybrid Audio Legathia 3-Way Active Front Stage * (2) Morel Ultimo 12's * (2) Arc Audio 1100.1 XDi v2 (Strapped @1ohm) * (1) Arc Audio 1200.6 * RF 360.3 DSP
kiko Posted December 6, 2013 Author Report Posted December 6, 2013 ported in the low 30's is highly suggested with proper airspace and port area you'll be very very happy! 32-35hz thanks for the suggestion vanquish, but i have no experience in designing a box. i need a design go by.. Thanks for the suggestion!!! =DD
VaNQuisH Posted December 6, 2013 Report Posted December 6, 2013 ported in the low 30's is highly suggested with proper airspace and port area you'll be very very happy! 32-35hz thanks for the suggestion vanquish, but i have no experience in designing a box. i need a design go by.. Thanks for the suggestion!!! =DD Download Torres Box Calculator from this forum... it's simple and gives you all the dimensions you'll need! Currently: * Hybrid Audio Legathia 3-Way Active Front Stage * (2) Morel Ultimo 12's * (2) Arc Audio 1100.1 XDi v2 (Strapped @1ohm) * (1) Arc Audio 1200.6 * RF 360.3 DSP
kiko Posted December 6, 2013 Author Report Posted December 6, 2013 i was thinking of a design like this but i would like someone to create one that is tuned to 33-35hz(the port is in the middle) Triticum Agricolam VaNQuisH Joe X
kiko Posted December 6, 2013 Author Report Posted December 6, 2013 or like this... where the port is on both sides..
