DC Sound Lab
I got a bunch of stuff to stick on this, its all product we built to test something, was left over from OEM builds or we made for someone that dident pay there Bill, I want to try to clean as much of it out of here by the end of the year. I got quite a bit so its going to take me a little while, check back through the day for new stuff.
1. Pair of level 3 12s we used to make the "whats it take to do a 150" video on you tube. 225 each shipped in the US (SOLD SOLD SOLD SOLD)
_ these i also put on Ebay
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=181278053118
The level 3 sub is the ultimate daily driver sub. It puts out the low lows with lots of output designed for sealed or ported enclosures.
The Level 3 sub is a triple stacked FEA optimized motor wrapped in a magnet boot, chrome top plate and T yoke. The deep gap offers more X-max for a total of 22.5mm.
This sub also comes with dual upgraded progressive spiders, cone, surround, 3" voice coil, cast basket,
push terminals, and upgraded sewn down lead wire. We give the Level 3 a power rating of 900w RMS/1800w peak.
Made with high quality parts and hand built in the USA, this is probably our #1 seller.
Key Features
• Extremely rigid non-pressed paper cone assembly
• Multilayered polymer foam surround
• Polypropylene dust cover with embossed DC logo
• Dual 8” OD semi cup progressive roll spider
• Extra heavy duty interweaved tinsel lead wire sewn to spider
• Cast aluminum black frame
• FEA analyzed and optimized motor assembly – Fully CNC machined
• Rubber mounting gasket
• Chrome spring loaded push terminals
• Dual 4 ohm 3” Hi-temp Aluminum voice coil wound on black anodized voice coil former
• Rubber magnet cover
10" 12" 15" 18" Mounting Depth 6.25" 6.75" 8" 9.5" Mounting Hole Diameter 9.35" 11" 14" 16.75" Outside Driver Diameter 11" 12.5" 15.7" 18.5" Motor Width 7" 7" 7" 7" Weight 20lbs 20.5lbs 21.5lbs 22lbs VC Diameter 3" 3" 3" 3" Displacement .15³ ft .16³ ft .18³ ft .22³ ft Magnet Weight 18lbs 18lbs 18lbs 18lbs Power Handling RMS/Peak 900/1800 900/1800 900/1800 900/1800 Impedance (Ohm) D1/D2/D4 D1/D2/D4 D1/D2/D4 D1/D2/D4 Sd 324cm² 481cm² 823cm² 1217cm² Vas 13.16 liters 28.99 liters 84.88 liters 185.6 liters Cms 0.09 mm/N 0.09 mm/N 0.09 mm/N 0.09 mm/N Mms 190 g 225 g 295 g 305 g Fs 38.5 35.4 30.9 30.4 BL 17.2 N/A 17.2 N/A 17.2 N/A 17.2 N/A Re 3.6 Ohm 3.6 Ohm 3.6 Ohm 3.6 Ohm Le 3.5 mH 3.5 mH 3.5 mH 3.5 mH Qms 7.66 8.33 8.18 8.32 Qes 0.567 0.617 0.706 0.718 Qts 0.528 0.574 0.65 0.661 Xmax 23 mm 23 mm 23 mm 23 mm Ref SPL @ 1 watt 83.1 dB ([email protected]) 85 dB ([email protected]) 87.3 dB ([email protected]) 90.4 dB ([email protected]) Suggested Sealed .65³ ft 1³ ft 2³ ft 4³ ft Suggested Ported 1³ ft 1.5³ ft 3³ ft 6³ ft
Edited by WCA Rusty
DC AUDIO
Phone Number
1(855)SPL-DBZZ
Built by Competitors, for Competitors.
2. 1 set of Lv3m2 10" recones but upgraded, these have Lv4 8 layer flat wound D2 coils and AR10 cone surround options.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=181278076753
These would normally sell for 154 each, or 308 for the pair, i will sell these for 200 shipped with glues
Edited by WCA Rusty
DC AUDIO
Phone Number
1(855)SPL-DBZZ
  • Who's Online   0 Members, 0 Anonymous, 6871 Guests (See full list)
