Correct way to wire 2 relays?
i still dont see the need for 2 relays. can someone explain why 2 relays are needed? the head unit will flip one relay on and you can run everything off of that relay.
One is for the parking brake bypass on a head unit. The other is for a remote to my bass amp. The reason that I have it on a relay is because my door amp is hooked up to the radio's remote and I don't want to shut off the 2 channel and the bass amp every time I press the button.
What the f**k is an appropriate signature supposed to look like?
2013 Kia Forte Koup
Pioneer AVH-X4600BT
iDMax 12
DD M1c @ 2 ohms
Rockford Prime 200.2
Pioneer 6.75" Comp Set
XS S3400, D2700
Project DB Battery Terminals
Axxess ASWC
Stinger HPM Everywhereeee
90 Sq. Ft. of Stinger Roadkill
Stock Alt
Stuff To Come
Sundown X-12
New Amp
New Comps
4 Channel Amp
My Current Build: http://www.stevemeadedesigns.com/board/topic/167462-13-kia-forte-koup-dd-setup/
My Old Build: http://www.stevemead..._+2000 +mustang
Avatar Courtesy of SnowDrifter
wy cant you hook the video parking brake bypass and amps all to one relay. i must not be understanding how the cirucuit works. but im just curious for my future knowledge.
BMW M340 xDrive
Best Scores out of a trunk
154+ windows down, 155+ kick
One relay switches ground the other 12v I used my head unit to turn on 4 amps a eq an dome fans before I doubt 2 relay coils will hurt it
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
One relay is going to complete a ground circuit for the parking brake wire. This is a bypass method so you can watch videos while driving. The green wire that you see in his pic is triggered by the ground. The second relay is for your normal stuff. That one is being fed a 12v constant to provide power to the remote turn ons.
2003 Tahoe
dc 7.5k
dc level 5 15's (3)
MMats 341's
xs power batts
lots of sky high cable
dual alts(came off the sky-high gmc and don't know who made them)
ipad in center console
vu-din in center console
all being ripped out and being sold
Ok I see. Thanks for info guys. Didn't know how the bypass worked. Nice.
BMW M340 xDrive
  • Who's Online   0 Members, 0 Anonymous, 3374 Guests (See full list)
