Correct way to wire 2 relays?
I need a relay for the switch to my bass amp and a relay for a video bypass. Would this be the correct way to hook it up?
What the f**k is an appropriate signature supposed to look like?
2013 Kia Forte Koup
Pioneer AVH-X4600BT
iDMax 12
DD M1c @ 2 ohms
Rockford Prime 200.2
Pioneer 6.75" Comp Set
XS S3400, D2700
Project DB Battery Terminals
Axxess ASWC
Stinger HPM Everywhereeee
90 Sq. Ft. of Stinger Roadkill
Stock Alt
Stuff To Come
Sundown X-12
New Amp
New Comps
4 Channel Amp
My Current Build: http://www.stevemeadedesigns.com/board/topic/167462-13-kia-forte-koup-dd-setup/
My Old Build: http://www.stevemead..._+2000 +mustang
Avatar Courtesy of SnowDrifter
Yes sir then from switch to amp right? Wire for amp is 12 v should be red like input not blue but I get your point
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
That is not correct and if you have it connected to a head unit, you'll likely damage it.
Are you using a head unit out to turn the amp and bypass on or will it be a manual switch?
Facebook: facebook.com/audioanarchyllc
Instagram: audioanarchyllc
Youtube: youtube.com/bbeljefe
why do you have 2 relays if you are jumping them? they both turn on when you flick the switch?
why not jsut get 1 relay to handle all the load?
BMW M340 xDrive
Best Scores out of a trunk
154+ windows down, 155+ kick
One is switching power, the other is switching ground, and neither is controlled with the switch. The switch will only be active when the headunits remote lead activates the relays.
But like bbeljefe said, that may damage headunit, bosch relays usually draw around 150mA each, and im not sure on every headunit, but I believe they are usually around 300mA max on remote line
max on a remote line output [from a headunit] is generally 150mA, and can be as low as 10mA in rare cases, neither will have an issue powering a relay. You only need enough amperage to get the coil to flip over which is VERY small, then all your output comes straight off the 12v side of your system (batteries)
I'm sorry, I was thinking backward with the pin designations for coil and contact. That said, I wouldn't switch both relays with the head unit remote.
2 of those relays will draw over 200-250mA...which both well exceed your given values for the supported output of a headunit, although I have never seen one as low as 10mA.
Someone correct me if I'm wrong.
Remote in should go to 86 on the second relay. Then grab the remote output from the second relay to turn on the 1st.
Then you headunit is just turning on one relay and that relay will turn on the relay for your bypass.
Again correct me if I'm wrong.
2003 Tahoe
dc 7.5k
dc level 5 15's (3)
MMats 341's
xs power batts
lots of sky high cable
dual alts(came off the sky-high gmc and don't know who made them)
ipad in center console
vu-din in center console
all being ripped out and being sold
i still dont see the need for 2 relays. can someone explain why 2 relays are needed? the head unit will flip one relay on and you can run everything off of that relay.
BMW M340 xDrive
  • Who's Online   0 Members, 0 Anonymous, 3374 Guests (See full list)
