focused313 Posted December 14, 2013 Report Posted December 14, 2013 I'll try to make this question actually make sense. I have a Clarion eqs746, It has a separate sub out control, however, if you turn the frequencies, they affect the subs and speakers. Meaning, if I turn up the 50hz, it goes to the speakers. If I have the crossover on the mid/hi amp set to a certain level, shouldn't the eq be irrelevant as far as turning up/down certain frequencies? Learning Everyday. Pioneer AVH-P4000DVD Alpine SPS-610C BXI-2008D (2) SWR-1242D / Ported
Acheskie Posted December 14, 2013 Report Posted December 14, 2013 Crossovers are designed to roll off brother. Set your crossover for 80hz and -12db and see what that does for you. Best of luck.
EP95 Posted December 14, 2013 Report Posted December 14, 2013 The crossover's on both the eq and the amplifier don't completely cut out the frequencies there set at they just turn them down by 12(or more) decibels, The amp is still receiving bass frequencies just at a much lower level than other's.
focused313 Posted December 14, 2013 Author Report Posted December 14, 2013 thanks guys. I already have the HPF on on the mid/hi amp, but I'll try to set the rolloff to 80hz. Learning Everyday. Pioneer AVH-P4000DVD Alpine SPS-610C BXI-2008D (2) SWR-1242D / Ported
Noel989 Posted December 14, 2013 Report Posted December 14, 2013 thanks guys. I already have the HPF on on the mid/hi amp, but I'll try to set the rolloff to 80hz. Terminology for future reference Roll off is the decreasing magnitude of the wave Hz is where you set it to start the roll off Build Log - http://www.stevemead...-cruiser-el-pt/
