OrionStang Posted December 14, 2013 Report Posted December 14, 2013 Ok guys, using the recommendations from Parts Express and the Dayton Ultimax 12", the port ends up being less than 5" per cube. Is it normal for port area to be less in a home setup than in a car? I need 4 cubes net tuned to 20hz, but not sure on port area. Using Torres to get a general idea. SMD Super Seller My Feedback Thread
fox_racin4 Posted December 15, 2013 Report Posted December 15, 2013 This is semi irrelivant but may help. I did a box for 2 18" BTLs for my basement, 24cubes with 3 10" sono tubes for ports. On 100rms ( maybe less) i was doing a 134ish at 25hz where i was sitting. 1998 gmc extd cab 12 crossfire C710s 4 SAZ-4500s 3 Singer 400A altsbuncha mids/highs Team Asshole
CleanSierra Posted December 15, 2013 Report Posted December 15, 2013 How much airspace are you planning on giving it Ken? The sub only needs X amount of port, regardless of what airspace it's in. With that tuning, I come up with around 20" of port. Im not the one you want to try to troll. Just a fyi for you.
OrionStang Posted December 15, 2013 Author Report Posted December 15, 2013 How much airspace are you planning on giving it Ken? The sub only needs X amount of port, regardless of what airspace it's in. With that tuning, I come up with around 20" of port. As stated above, 4 cu ft after all displacements. I've come up with a design that is 21.75" of port. Guess ill start there. SMD Super Seller My Feedback Thread
