Guest SyKo13
What you did to the rear looks pimp, I never thought of that myself  ;) ;)SK >:(
Here's some vid I threw together.  The subs still aren't broken in and I need power upgrades and I need more power.....
Posted Image
A little door flex
Posted Image
A little windshield flex
Posted Image
some remote fun
Posted Image
Posted Image
It's a start not to bad for 10's in a sealed box
it looks real nice man, looks like its bass'n perty good. nice job keep the updates Comming
:^ Thankyou.. Each day it seems to get louder. The big three helped and the subs are braking in nicely. Need some power supply upgrades, my lights are dimming more and more as well :V. I'm hoping in a few weeks to get a batcap 400 and before I do anything else get it metered. I want to be able to know if I'm improving or spinning my wheels as I keep building. ;)BTW, I realize this is not an spl build, but I want to see what #'s I can get in a DD. I plan on turning this into SQL and some db runs on the side. I'm hoping like hell to start a spl rig this winter.
  • 3 weeks later...
  • 1 month later...
Man nice work on the install.
Srry to hear about the vinyl on the rear deck I was about to ask if you did the vinyl yourself or outsourced it to a shop-CUZ IT LOOKS GREAT! The areas around the 3rd brake light, i was like OMG-that had to be tricky. In my exp the only way to get the vinyl down good and stay put is use the highest TACK glue you can find (I use 3M and the higher ## the better like 77 vs 90, i use 90 & it seems to work), also after you apply the glue and press the vinyl down i find that WARMING it by rubbing it or heating it a hair dryer/heat gun helps the glue to set quicker and stay where u want it rather than staying wet too long or "flash drying" when air hits it. Also in really stubborn areas I've used thicker glue than spray adhesive (shamefully liquid nails in one case but it worked perfectly) and just thinnly coated and then weighted/clamped it overnight if poss.
As far as spl-maybe check/try to clear up some space at the top of the enclosure so more air can find the cut thru?
-Just my 2cents.
COOGLE SAID:"bro thats how we got where we are... buy making messes ...... i still learn all the time you just gota be willing to ruck up some shit" "In order to attain the impossible, one must attempt the absurd." ~ Miguel de Unamuno"One machine can do the work of fifty ordinary men, but no machine can do the work of one extraordinary man" -Elbert Hubbard"A proud man can learn humility...but he will be proud of that too" ~I forget who.I'm far from perfect and I know it better than anyone, but I hope to be good at what I do, when I do it...Installs I've done:My Integra: http://www.stevemeadedesigns.com/board/ind...?showtopic=3161The Lexus : http://www.stevemeadedesigns.com/board/ind...?showtopic=1535Law's Maxima: http://www.stevemeadedesigns.com/board/ind...ic=5568&hl=Jeff's 2500HD: http://www.stevemeadedesigns.com/board/ind...ic=5382&hl=Acura RSX-S: http://www.stevemeadedesigns.com/board/ind...?showtopic=3142Z-32 300zx: http://www.stevemeadedesigns.com/board/ind...?showtopic=34602004 Civic 4dr: http://www.stevemeadedesigns.com/board/ind...?showtopic=8190Trunk/Corner Box: http://www.stevemeadedesigns.com/board/ind...c=16036&hl=1969 Chevy C-10: http://www.stevemeadedesigns.com/board/ind...c=20319&hl=Seat-Back AMP-RACK How-to: http://www.stevemeadedesigns.com/board/ind...ic=9428&hl=Bunch of subs still for salehttp://www.stevemeadedesigns.com/board/ind...l=lsn2meboom916"It's game night...we're playin......sex."~Quagmire"When disneyland started it was powered completely by orphan children running on treadmills to generate e-lectrissty…and today, them children are New York Yankees". ~Dale Gribble"Fill it with ice...then pour it up to the top of the ice...& Shut da Fu** up!" ~Urs truly.
  • Who's Online   0 Members, 0 Anonymous, 4078 Guests (See full list)
