port ratio help!
cgallmore
Im designing a box for 2 obsidian audio 15s, i looked on the web and didnt really see any thing that helped with port ratio.
so far the box i have a
7.88 box
115.50in2 port area
14.65 port area per ft
1:2.36 port ratio
What are you wanting to tune the box to?
Krakin's Home Dipole Project
http://www.stevemeadedesigns.com/board/topic/186153-krakins-dipole-project-new-reciever-in-rockford-science/#entry2772370
Krakin, are you some sort of mad scientist?
I would have replied earlier, but I was measuring the output of my amp with a yardstick . . .
What you hear is not the air pressure variation in itself
but what has drawn your attention
in the two streams of superimposed air pressure variations at your eardrums
An acoustic event has dimensions of Time, Tone, Loudness and Space
Everyone learns to render the 3-dimensional localization of sound based on the individual shape of their ears,
thus no formula can achieve a definite effect for every listener.
Everything looks good, but when figuring port length, make sure that you use the NET internal volume.
If you use gross volume you will build a box that will be way off what you expected.
Edit: You could bump up your port area a little bit, but you should be okay with it there.
okay it is the net volume! i made that mistake with my last box, and i didnt use the number of port walls either so my tuning was off. but i wont make that mistake again lol
  • Who's Online   1 Member, 0 Anonymous, 5337 Guests (See full list)
