Alternator install question
I have 2 Mechman 320amp alternators. When i get them installed, can I connect the positive leads with aluminum flat bar and make all my runs to the batteries off the aluminum?
Another question.. I have a stock 140amp alternator that will still be in place. I can get a longer belt to run the stock alt or a shorter belt and not route the belt along this alternator. Would there be any negative effects to running 2-320amp alts and 1-140amp alt? Should I not run the stock alt?
Yes you can run all 3 alts
Yes you can use the aluminum bar on the 2 alts
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
can you Post pics of the fabrication? I've been wanting to run 2 for a long time but never seen the process
jvc deck
stinger 1800 front
hc 2000 kinetic rear
2 runs of 1/0g
big 3/4
ct 60.4
2 ct 1400.1
ct EXO 15 d1
lots of deadner
type r comps front stage
6 kicker tweets rear stage
lots of great stuff
coming soon
ho alt
more bats
ct comps for front stage
more deadner
sweet amp rack
lots of L.E.D lights
new deck (thinking 80 prs, or flip out)
Thanks! Just to verify and be 100% sure, the 2 stronger alts wont "fight" the weaker alt?
Ill be installing them in a 4.2L trailblazer, and to my knowledge there are only 2 out there with dual alts. Im shooting for 3 and this application will require a little more than a typical bolt on bracket but i will be sure to take a lot of pics.
They will.not fight each other you may have pcm issues but thsts not the alts its the vehicle. I csnt say for certsin if that will be the case. Good luck though
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Externaly regulate them. Your trucks pcm that controls alt blows and charges way low ( did on buddys anyways)
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
  • Who's Online   0 Members, 0 Anonymous, 3374 Guests (See full list)
