mrrairai Posted March 6, 2008 Report Share Posted March 6, 2008 I have some aluminum bus bars that I drilled holes in. What can I use to smooth it and get rid of the excess metal. Thanks. Member since 25 Jun 2006 2011 Yukon DenaliCustomLightz 4300K HID RetrofitEsky TailsEsky Third BrakeEsky 22sEsky Appliques Link to comment Share on other sites More sharing options...
trainman0978 Posted March 7, 2008 Report Share Posted March 7, 2008 Depends on what kinda finish you want it.... Start with a wire wheel or a file for the deburring process the wire wheel ( a soft one) will change the appearance of the finish, where as a file ( a round or a skinny flat ) will just get at what ever you put it up against.... To cut it, just use a hacksaw with a new blade and go slow till you get a good groove cut, Its probably not worth buying a metal cutting blade for your miter box for one or two cuts... 2007 Toyota FJ Cruiser Voo Doo Blue my upgrades and "build" thread. My Kulicki Box Build -Alpine 9887 head unit, KTX-100EQ imprint-( sound quality for dummies! ). - MB Quartz 3.5" in back pillars -Sundown Audio SAX100.4 - JL Audio 3 way 6.5" component set XR653-CSi ( doors and dash ) -JL Audio 2 way Component set XR650CSi - Alpine MRD - M1005 - Alpine Type - R 12" subs -- 2 - 12" s in a Pete kulicki designed box. -Alpine High speed Ipod cable, and KCA-SC100 with Sirius sat. radio -All wiring is Stinger 12 gauge and HPM Level 3 RCAs, KnuKonceptz Kolossus Power and ground and Big done in 1/0, -270 sq. ft. of Damplifier Pro, 36 sq. ft. of Overkill Pro, 6 full sheets of Luxury Liner, and a gallon of spectrum- -2 Powermaster D680 Powercells in back FINALLY !!! I GOT IT METERED ON THE TERMLAB !!! I did a 140.2 at 42 hertz. Shoehorn, BFH, forklift,duct tape and some zip ties Link to comment Share on other sites More sharing options...
reinke Posted March 7, 2008 Report Share Posted March 7, 2008 the best thing to use and predrill the holes is gonna be a step drill bit. it drills and then debers ----reference's---- meade916 Link to comment Share on other sites More sharing options...
