Building a enclosure with slanted front
shanesauce
Just for future reference, what is they best/easiest way to construct a slant face box?
I am assuming you would put the box together as usual leaving the front plate for last and then finding the angle of the slope and cutting the back, "top" and front sides to the same angle?
- 2012 Mustang 3.7 Manual
- Audio under construction
Using a table saw is how I did my regular cab boxes. Get everything marked, check again, and then cut the side pieces. Use the side pieces to change the angle of the blade to match the top/bottom edges you make everything flush and flat.
PM'd you a link. I always put together the box with the side that has the speaker hole as the last piece. the link will show you why.
if nothing changes, nothing changes
You don't know what you don't know, till you don't know
  • Who's Online   1 Member, 0 Anonymous, 859 Guests (See full list)
