David Mears Posted December 28, 2013 Report Posted December 28, 2013 So I finally got my 2 15s. They're fi bl 15s, fully loaded. These will be going in my trailblazer. Im stuck between sub up/port back or both going backwards. I am using torres box calculator for my new box. Which type of box would be better? Also, when fi says 3-5 cubes each sub, is that GROSS volume or NET. Im very confused and would like to get this built soon. Since i have 3200 rms going to the subs, I would like to make the box around 8 cubes( Net or gross)? I am very lost and need help ASAP so experienced people don't shrug this topic away!
David Mears Posted December 28, 2013 Author Report Posted December 28, 2013 My vehicle doesnt have a massive cargo space either, dimensions are roughly 45 wide, 20 deep and 22 tall. idk if i should put my equipment behind the seat and the subs up against the hatch, or the opposite? The box may need breathing room. Then again it all depends on which way I face the subs and what style I do.
David Mears Posted December 28, 2013 Author Report Posted December 28, 2013 I also dont know what style of box i should do. If i go port back and sub up, what does the port going back look like? An l port on the side, bottom, or cube port like meade? Or if I go both back do I do seperated chambers or single? I need a rundown of all of this info before I pay for a box to be built
Miguels Posted December 28, 2013 Report Posted December 28, 2013 what car did you get? with the measurements it looks like you only have 9 cft with just 1 layer of 3/4 wood my logshttp://www.stevemead...-my-new-set-up/my blow through loghttp://www.stevemead...future-updates/ 96 ss http://www.stevemeadedesigns.com/board/topic/164094-96-impala-ss-build/
David Mears Posted December 28, 2013 Author Report Posted December 28, 2013 I got a 2005 chevy trailblazer.I gotta have room for my amp to lay down in the back with 2 kinetiks
David Mears Posted December 28, 2013 Author Report Posted December 28, 2013 i need 6-10 cubes, since its powering it at its max potential i was gonna do around 8 to not be too big and not too small. If i was doing less power id do the full 10 cubes. But im very inexperienced with suvs and car audio. This is my first SUV
Miguels Posted December 28, 2013 Report Posted December 28, 2013 you can set the amp on the back seat and the battery by it and it will give you more room.. i have had good results with sub up port back my logshttp://www.stevemead...-my-new-set-up/my blow through loghttp://www.stevemead...future-updates/ 96 ss http://www.stevemeadedesigns.com/board/topic/164094-96-impala-ss-build/
David Mears Posted December 28, 2013 Author Report Posted December 28, 2013 If im planing on doing sub up port back, how will the box be set up? Both subs up and the port as a slot? Seperated chambers? Shared? The port on the side or bottom? I dont know how to do any of this theres a lot of factors
David Mears Posted December 28, 2013 Author Report Posted December 28, 2013 Hello? If i do subs up port back, what kinda port do I use? 3 common walls, 2, 1, or 0?
CleanSierra Posted December 28, 2013 Report Posted December 28, 2013 I'll give my opinion in a minute Im not the one you want to try to troll. Just a fyi for you.
