question on battery
when I look at a 16 volt battery or even the 14 volt battery how can you even charge them when using them in your car/suv/van/truck? thought mostly everything is based on a 12V for your electrics that run. or do people use the 16s 14s some how and place them in a battery isolator just for the music? still don't get how the batterys in the higher Volts even work out for any vehicale?
& you'll usually see a 12v alt then the 14/16 for audio
Team Subsonic Lows
Get your garbage EMF products of my amp bitch
Man....it makes a nice work bench ;)
People will generally run a 12v alt, and a alt with a regulator up to 14v/16v/18v. Then you can run the higher voltage to all your higher voltage batteries and amplifiers, and use the 12v alt to charge the 12v starter battery and run OEM accessories and maybe the headunit.
You essentially have 2 independent electrical systems when you do this.
Or, you can use a step down module, regulate the alt to 16v, and use the step down and use that lower voltage (ex. 12v) to run the OEM stuff, and 16v to everything else.
  • Who's Online   0 Members, 0 Anonymous, 3472 Guests (See full list)
