qwilkins Posted January 2, 2014 Report Posted January 2, 2014 Im building a new box,but this is my first time actually trying to build a ported box i need some feedback on the design.The design via google sketchup: https://www.dropbox.com/s/n6vqtito0gxoi0j/36Hz.skp If i did it right the box should be tuned to 36 Hz and have 7.844 ft^3. thanks in advance. forgot to mention im using 2 l7 15's
hdorre Posted January 2, 2014 Report Posted January 2, 2014 Why not use 1 port? On 5/8/2011 at 7:38 PM, Kranny said: On 5/8/2011 at 7:35 PM, 'Maxim' said: It hurts me inside when I read stuff like this and remember you're 15 LMFAO so true Mitsubishi 3000GT (Old Build) Headunit: Pioneer 80PRS Frontstage: (2) McLaren Audio MLT-2 Tweeters & (4) PRV Audio MR Series Neo 6.5" Mids Substage: 4 15" Hybrid Subs - Tantric Motors & Sundown Softies Amps: Banda 2.4D Amp (Tweets), American Bass VFL 350.4 (Mids), and (2) Ampere 3800s Electrical :Singer 260A Alt & JY Power Lithium 2005 Chevy Colorado Ext Cab Headunit: Pioneer 80PRS Frontstage: 4 PRV 700Ti Tweets & 6 10" Delta Mids on 3000wrms Substage: 6 Fi BTL 18s in a 4th Order Walkthrough on 3 Wolfram 4500s Electrical: Singer "390" and JY Power My Official Feedback Thread
qwilkins Posted January 2, 2014 Author Report Posted January 2, 2014 Why not use 1 port? I wanted to have the individually ported to see the difference between common chambered and separated ported boxes
Joe X Posted January 2, 2014 Report Posted January 2, 2014 Your calculations look wrong. If I got your dimensions right 16 3/4 x 45 1/2 x 20 3/4" you have about 3 cubes of net airspace for each sub which is too low for them, it's at least more like 4 cubes net each what will work nice with those.
qwilkins Posted January 2, 2014 Author Report Posted January 2, 2014 Your calculations look wrong. If I got your dimensions right 16 3/4 x 45 1/2 x 20 3/4" you have about 3 cubes of net airspace for each sub which is too low for them, it's at least more like 4 cubes net each what will work nice with those. Ok so, if i add 5 more inches to the width making it 50.5 should have about 5, but then with the space the wood is taking up i should have a little of 4 left over right?
Joe X Posted January 2, 2014 Report Posted January 2, 2014 Going 50 1/2W, would up it to about 3.4 cubes net per sub from nearly 3 cubes, still a long way to go.
qwilkins Posted January 2, 2014 Author Report Posted January 2, 2014 Going 50 1/2W, would up it to about 3.4 cubes net per sub from nearly 3 cubes, still a long way to go. Can only go up to 55 in length 20 dept 17 height. That's the max i can fit in my trunk. so 16.75 X 54 X 19.25 wouldn't work either? sorry i forgot that you have to use a different formula to calculate air space for ported boxes .
Joe X Posted January 3, 2014 Report Posted January 3, 2014 17x54x20.75 would figure to 8 cubes net @ 36Hz, to keep tuning to 36Hz port area would need to be kind of low, it will work ok but may not be very efficient if you go all out on power.
