ok idk if this was a topic already or not. but i was wonderin how i can rattle and sound proof my car. i already know about dyno mat, but my trunk still seems to hyperflex so i was wonderin if there are other ways to seal it so that it wont rattle and sound wont seep out. and if so how would i do it
Fusion With A Stetsom 4k2d on 2 DC XL 15s tuned to 31hz and Subs and ports forward
The Revolution Was Not Televised
But There Is This Thread(clicky)
Dr Merkenstein is my 360 gamertag and my profession. When shit gets real, call in the Doc
bizzump come on i know someone on here has ideas on how to stop trunk flex. i think i remember seein somewhere about caulkin the trunk liner a long time ago, but how would i go about doin that one if it actually works
you can put spray foam in the "ribs" of your trunk, let expand out, then trim away the excess, but ultimately the only way is several layers of some sort of sound deadenening product , either as foil backed sheets or a paint on type of deadener...
2007 Toyota FJ Cruiser Voo Doo Blue
my upgrades and "build" thread.
My Kulicki Box Build
-Alpine 9887 head unit, KTX-100EQ imprint-( sound quality for dummies! ). - MB Quartz 3.5" in back pillars
-Sundown Audio SAX100.4 - JL Audio 3 way 6.5" component set XR653-CSi ( doors and dash )
-JL Audio 2 way Component set XR650CSi
- Alpine MRD - M1005 - Alpine Type - R 12" subs -- 2 - 12" s in a Pete kulicki designed box.
-Alpine High speed Ipod cable, and KCA-SC100 with Sirius sat. radio
-All wiring is Stinger 12 gauge and HPM Level 3 RCAs, KnuKonceptz Kolossus Power and ground and Big done in 1/0,
-270 sq. ft. of Damplifier Pro, 36 sq. ft. of Overkill Pro, 6 full sheets of Luxury Liner, and a gallon of spectrum-
-2 Powermaster D680 Powercells in back
FINALLY !!! I GOT IT METERED ON THE TERMLAB !!! I did a 140.2 at 42 hertz.
Shoehorn, BFH, forklift,duct tape and some zip ties
well i know dyno mat but my subs literally push my whole trunk out. and it slams back into the frame, but it sounds ALOT better with pressure on the trunk, so i figured it might just be that and i can cushion it alone the outer part since my trunk is mounted on the outside of the trunk and doesnt go inside of it
"alone the outer part since my trunk is mounted on the outside of the trunk and doesnt go inside of it" .... Ya lost me there.
Bottom line is you need to add density to those panels, and density comes in the form of weight , which is layers of sound deadener. something else you can do is get some insulation or polyfill, and stuff down into the empty cavities of your trunk , and pack it down good, that will be a improvement if you have big trunk like a old caddy or box chevy , but you dont want that stuff exposed cause it will always be a big mess. If you can put it behind a trim panel than you will prolly like the idea a little more. Who wants to open a trunk and see pink fluffy insulation sticking out of the body skeleton?
lol i figured someone would get confused. ok i drive a fusion, the trunk LID is mounted on the trunk. it doesn have that arm that goes inside of it. its basically like a car hood. ive already dynamatted my trunk lid, but it doesnt rattle it actually pushes out literally the exact way my subs move, and it slams back into the outer part of my trunk
Again, I say ...:) Sound deadener, more layers. maybe 3-5 layers. The heavier it is the harder it will be for the air pressure to move it
hmm thats alot of layers >.< lol ok guess ill try that then
