Notched the socket and got it in. Caulked the parking lamps in place. Got 2/3 of the bolts back in. The one is behind a bumper mount so I cant access it... but the light has a decent cutoff line at the top of the one side thats done. My left flasher is going crazy tho but ill just deal. Everything is working so im happy. Any tips to get that bolt back in or out tho? Ill finish the other side later on hopefully.
My SPL to SQ Build Log
Vehicle:
1997 Dodge Dakota Ext Cab 4x4 2009 Dodge Journey SXT
5.2L V8 Magnum 3.5L V6
Stock Alt
Equipment:
Headunit- Alpine CDE-147BT
Mids/Highs Amp- JL Audio G6600 Class AB 6 Channel
Sub Amp- Hifonics BRZ1700.1D @ 2 Ohms Taramps DSP3000.1D
Sub- Hertz Hi Energy 12" HX300D SounDrive SDA3 12
Tweeters- Rockford Fosgate Power Series Silk Domes Hertz Hi-Energy
Mids- Dayton Audio Reference 4" Full Range Drivers
Midbass- Silver Flute 6.5" Hertz Hi-Energy 6.5"
Processor- MiniDSP 2x4
RCA- 6 channels of SounDrive HF series
Wire- EB Flex 2/0
-Member of Team SounDrive
i know that autozone usually has the sockets you can buy all you need to do is cut off the original and solder the new i would suggest to leave some wire on the original in case you want or need to go back to that you can just solder it back on. sorry i though you meant the connecter that goes to the bulb.
I just shaved it down and it fit perfect. Got the bolt out but its not going back in.
Vehicle:
Stock Alt
Equipment:
Wire- EB Flex 2/0
  • Who's Online   0 Members, 0 Anonymous, 977 Guests (See full list)
