Trying to install these new headlights but the corner signals dont match up. The socket on stock is the 4 point like a cross socket. These new ones are only a two point like a minus on the socket. I was thinking of either cutting the two prongs off the stock socket or notching out the headlight. If I didnt work right id end up using plastic cement between the joint to hold it.
My other issue is the parking lights I busted the socket on one trying to tighten it but I discovered that they are just loose in there. So I gotta pick up a new one at the junk yard. Or could I just cement it in place also?
My SPL to SQ Build Log
Vehicle:
1997 Dodge Dakota Ext Cab 4x4 2009 Dodge Journey SXT
5.2L V8 Magnum 3.5L V6
Stock Alt
Equipment:
Headunit- Alpine CDE-147BT
Mids/Highs Amp- JL Audio G6600 Class AB 6 Channel
Sub Amp- Hifonics BRZ1700.1D @ 2 Ohms Taramps DSP3000.1D
Sub- Hertz Hi Energy 12" HX300D SounDrive SDA3 12
Tweeters- Rockford Fosgate Power Series Silk Domes Hertz Hi-Energy
Mids- Dayton Audio Reference 4" Full Range Drivers
Midbass- Silver Flute 6.5" Hertz Hi-Energy 6.5"
Processor- MiniDSP 2x4
RCA- 6 channels of SounDrive HF series
Wire- EB Flex 2/0
-Member of Team SounDrive
why dont you splice in the correct socket for the headlamp itself? or do you not have the correct socket? i wouldnt notch anything or cut anything without doing some more research first....... find the correct socket and solder and heatshrink it in.
just my .2
i think there real i was looking through that guys stuff he sells and it looks like he finds stuff at auctions and just sells it
Yea, it looks like someone got the mids about a month ago....shit. If I had a whole Hertz front stage my ears would jizz all over my cheeks.
/ LOL
My Low Budget Build:
Green 1995 Subaru Legacy wagon 147k- $1K
headunit- pioneer premier deh-p650-$25
4 Lead acid batts. 1 up front and 3 in back- vented outside.- $50
4 vvme L11 10"s <- $30 shipped a piece
6 cu. ft box (after displacment) tuned to 32ish hz with 10 inch sonotube. -about $50 all together maybe a lil more
2 aspm 1300 strapped
Selenium 6"s in the front doors on headunit power- for now -$20
quantum tweets in door-for now -$10
boston acoustic 5 1/4 in rear doors- for now-Free
big 3
1/0 and 4awg throughout.
roof sound deadened (not peel n seal ftw)-free
on 80 amp alt (bench tested to put out 100 amps faithfully) <--?-$10 for test
about $430 for everything<----Not bad at all
still gotta add 3 way crossover, amp for front and rear door speakers and maybe eq
Stock is the black. New is the silver. Do u know what kinda socket thatd be? Corner light btw. And then what should I do bout the two others? Cement them in once they are on? Ill put fresh amber bulbs in them.20140108_180435_zpsq8vfnk2a.jpg
Vehicle:
Stock Alt
Equipment:
Wire- EB Flex 2/0
U have a dremel?
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
I went to autozone and asked. They didnt have anything or seen it before. The new headlights are aftermarket. I shouldve said that. I planned on just using a dremel though.
Vehicle:
Stock Alt
Equipment:
Wire- EB Flex 2/0
Don't ask for advice at autozone lol. Most of those guys are idiots.
If you notch it with a dremel or anything remember to vacuum it out good.
And the fact more than one person agrees does not make it a circle jerk, it makes it a bukkake scene and you're in the middle ;)
Chick took 3 shots of Jager, and then, pissed in my mouth..
B5 Passat Build Log
anyone got anything on that connector?
Vehicle:
Stock Alt
Equipment:
Wire- EB Flex 2/0
Vehicle:
Stock Alt
Equipment:
Wire- EB Flex 2/0
Notch out the socket as mentioned above. No need to start splicing wires and changing connectors unless of a last resort. Using a dremel will only take a few minuets. And you will maintain your stock connector.
truthsayer
  • Who's Online   0 Members, 0 Anonymous, 977 Guests (See full list)
