vfl 80.1 no output
Hertz_dont_it
It's my buddies system, vfl 80.1 and two 15"xd's. I originally hooked it all up. With him only having one run of kicker 4ga I figured id wire each sub to 2ohm and run them separately to the amp because I didn't think he had the electrical to be running them at one ohm. I had the gain about 1/4 up bass boost all the way down when I installed it. He comes to me and says his subs dont work so I checked all the wires. Put a multi meter to the rca's only one had any output and it was like .14 the other was zero. He was in a hurry so I couldn't check the back of the stereo. But the rcas are hooked up on rhe back I just couldn't get the multi meter to it. Is it the rcas or the amp?
Current system:Front stage: Alpine type s 6.5No rear:Alpine type s 6.5headunit: alpineAmp: Jbl bp600.1
Sub: Alpine type x 12
dont know much about them. Found a "FLUX" Capacitor on ebay. If I add this to my system, can I really travel into the future? And how far into the future? That probably all depends on how I ground it though, right?
Dude dont even waste your money on capacitors get a second car battery preferably a kinetik or stinger or any other car audio battery use the battery that is correct for your systems true rms wattage do some research on the net for this. Go to kinetiks website they explain how to pick a battery from thier site that fits your system. :shrug:
You wired them at 2 ohm separately to the amp. Sounds like you wired them to 1 ohm and killed the amp due to insufficient electrical.
I thought since I wired each sub individually to the amp it would only be 2ohm. Oh and I just looked at his settings on the amp. Bass and gain are all the way up..im just gonna try hooking it up in my truck to see if it works
It's a single channel amp. Just has two inputs that tie in. ++/--. May be a dead amp.
Took the amp all apart, nothing black/brown, burnt. Put it all back together, hooked it up in my truck and it works. His rca's?
Could be. Is he getting voltage at the amp? Maybe a blown fuse on his part. Bad RCA's, bad remote, bad headunit.
Amp powers on in his, just no sound. Im gonna start from the head unit and work back to the subs when he comes back
Thanks for the help 50
No problem man. Update when you find it out.
  • Who's Online   0 Members, 0 Anonymous, 636 Guests (See full list)
