Need help finding a HO Alt.
Good choice on singer. Just ordered mine with the pcm add-on and xs vcm
Team Subsonic Lows
Get your garbage EMF products of my amp bitch
Man....it makes a nice work bench ;)
Well pcm addon is the regulator. VCM let's you charge higher.
Team Subsonic Lows
What does VCM stand for so I call look it up? and also my mechanic told me my alt is computer controlled, will the singer be also? If it does, how will it know to push 220 amps?
I believe VCM= voltage control module......He gave you a voltage regulator option since yours is usually controlled by the computer like your mechanic said. Oh, and don't run a 16 volt, (16v batteries charge around 18 volts and your vehicle won't like that) You can run it separately from your normal charging system, but that will require it's own batteries and alternator.
AA-Atomic-Clif Designs-DC-Diamond-Digital Designs-Directed-Eclipse-Fi-Hertz-Hifonics-Kenwood-Memphis-Phoenix Gold-Pioneer-PPI-PSi-Stinger-Sundown-TC Sounds-Viper-Zapco
I found this wiring diagram somewhere and the guy was saying he was using his 12v for his car then could switch it to charge only the rear and leave the 12v alone.
Would this work?
  • Who's Online   0 Members, 0 Anonymous, 3374 Guests (See full list)
