Box design help?!? does this look good?
alenv10
I dont know what the exact displacement is but would assume it is around .2
06 monte carlo
2 12 rockford p3s
soundstream rubicon 2500
crescendo audio mezzo 6.5
ct sounds 125.4
execution audio and shca wiring
2 xs d3400 on stock alt
It would help us help you if you listed the exact brand, model, and size/ohm/voicecoil(s) of the subs. The TS parameters of the sub are almost as important as box parameters, knowing the brand and model will help us find the parameters.
Also, Might I suggest building a 3-D model of the box first in the free Google Sketch-up, Here's a link to a how to video to get you started
https://www.youtube.com/watch?v=ZCeUB63Sjks
Hope this helps, good luck.
Knowledge is the greatest tool in any garage. It's also the most priceless, and most easily shared. icon_nuts.gif
Here's my latest build.
http://www.stevemeadedesigns.com/board/topic/181273-89-c1500-build-log/
Avoid more then 1 port bend with slot Ports to, port bends can hurt port efficiency. less bend the better.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
bracing or a double baffle and the box will need to be a but bigger due to sub displacement and any other bracing displacement our baffle displacement.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
Figure out sub displacement and do the flush mount with double baffle. Then post new specs for the box and a sketch up of it. It will help people visualize things that could help.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
okay here are the new numbers with the sub displacement, and the box design.
everything looks great to me except the space i will have between the sub magnet and the port wall...
i will have about 4 inches from back of magnet to port. will that be a huge issue?
other than that, its
2.04 cubic ft.
34.72 htz
18.38 in^2 of port area
double baffle, flush mounted
Does it all look good?
NOTHING DOWN HERE YET :(
OBSIDIAN FTW
  • Who's Online   2 Members, 0 Anonymous, 1794 Guests (See full list)
