89 C1500 Build log. 144 @ 28hz, loudest single cab w/o blowthru?
Tried out some Gunmetal grey Plasti-Dip one one of my mirrors, we'll see how it turns out in the morning. That stuff is great! But I got a little over-spray on the window and door, so I'll have to rub that off. Damn wind! If this stuff looks really good, I'll get the Blaze Orange and add some purtty accents inside.
Knowledge is the greatest tool in any garage. It's also the most priceless, and most easily shared. icon_nuts.gif
Here's my latest build.
http://www.stevemeadedesigns.com/board/topic/181273-89-c1500-build-log/
Okay I'm looking at two big amps, the Crescendo bc3500d and the Ampere Audio AA-3800.1D Both are exactly the same price, and they both are stable up to 18V. Very close RMS numbers as well, 3875 vs 3800, respectively.
I'm beginning to lean more towards the Crescendo because it comes with a clipping indicator and is stable a .5 ohms. Anyone have any input? Thanks in advance.
Either amp, they'll both make you happy. It's the same board I believe. The Ampere is the same as the SAZ3500 from Sundown.
Whats the price on those amps? I was looking at a bc 3500 but found out i could get a ddm3b for same price
Same price? For a M3b? Because I found the M3b to be over 1200, and the crescendo is less than 800. I know that a DD is top of the line on real world power systems, so if you found a brand new one for under 800, please post a link! I'd say both amps are really close RMS wise, so unless it's really the same price, I'm thinking crescendo.
You would love either amp. Have you decided on what type of sub your gonna run?
750??! Yeah, fuck that. Fuck this website, fuck SMD, fuck Steve, fuck all of his butt buddy mods, and their couches.
^ DON'T BE A DICK LIKE THIS GUY :)
Team Subsonic Lows
Not really. There's a Skar audio 15 (IVX-15v2) for 80 bucks, and that's a really appealing price for 15. and then there's the high end monsters. Like DD9915, which has 47mm Xmax and 2.5k rms, 10,000 watts peak. I have so many options to choose from, I want the most bang for the buck, and the biggest lows. Cheap stuff can get the job done, it's been proven many times, but I want to beat the block down. I want to set off car alarms and have people yelling at me and hairtricks and all that ground pounder stuff, and without a blow thru.
So, does a certain sub come to mind? I guess my goal is all out Ground Pounder.
Soundqubed HDC3
Sundown X or Zv4
Psi platform 2 or 3
Dc Audio lvl 4 and up
Ct Sounds Meso and Exo
If you're set on the bc3500, I'd run 2+ subs. I'm sure what ever you choose you're going to be pleased with.
2003 F-150 Single Cab
Pioneer 80prs
All KnuKonceptz 0ga Wiring (all soldered using Sky High Lugs)
Sky High Fuse holders
Big 3 with redtop
Karma SS RCAs
Eclipse EA4000 for Mids
Rockford Fosgate Punch Pro 6.5s
Crescendo RTS-1 tweets
Audio Technix AT1200.1d for Sub
Soundqubed HDS312
Box 2.65cubes @ 32Hz 6'' Aero port
Stock 130 Alt (looking at a Singer 270 Alt)
