Upgrading the stock alt
So i was wondering what is yalls opinion of getting a second stock alt for my sonic and taking it to a shop around me so they can upgrade the amprage from 100 to about 175 to 200. Then replace the one in my car now with the upgraded one along with doing the big 3.
2012 Chevy sonic1xSQ HDC3 12 D2RF R1200d
140 square foot of Q-Mat(soon to be installed)
140.2Db sealed on the dash with TL
142 DB sealed on the dash with another meter (was dead on with the TL at a show i was at)
141 on music.
strangeduck,on 02 Jan 2014 - 01:39 AM, said:
when my car spins out i just put the car in neutral, turn in the direction i want to go and pucker my asshole
Bump
141 on music.
I think you'd probably just be better off adding a single H/O. Should be around the same price range
Thanks alaskanzx5 I might just do that
I can recone a sub myself. About a year ago I took 2 12" power acoustic mofos and made one sub. I took the magnet and the motor off of one and j b welded it to the other motor and magnet. I had to wind my own voice coil so it would work. After I was done hooked up to 2 boss 5000w amps. And shattered my back and all my side windows
came to this thread to recommend soundqubed and ct sounds. OP goes with soundstream.
oh lawd.
I would be running 1 alt i just would like a direct replacement for the one i have. As of now mechman does not have one for my car. I need to still contact dc power.
141 on music.
try singer too.
the thing is with bigger internals in a stock case is heat extraction. stock case wasn't designed to handle the extra heat. can lead to shortened life of components
Ok i will try and contact them also. I dont want to buy or get one rewound and it go bad. Also cant spend a arm and a leg on one.
141 on music.
try singer too.
Exactly- that is why we won't build an alternator for a vehicle if a larger / more efficient replacement housing is not available.
If we don't offer a unit for it, it is probably because the OEM alternator design is already maxed out for good idle output and durability.
Ok guys and thanks for all the help ^_^
141 on music.
  • Who's Online   0 Members, 0 Anonymous, 3249 Guests (See full list)
