Fuses on amp keep blowing :(
FrontierGello
I have 2 mono amps and one amp keeps on blowing its fuses. The other one works perfectly fine. And they share a 300amp fuse at their wires.
it didnt pop. Amp might be blown?
Nissan Frontier
10" Cadence Midbass
8" Cadnece Midrange
Bullet tweets
2 Re audio Sxx 15 Subs
Mechman 270a
2 Re XT4000deV3 mono 1600 rms
1 Re XT400deV3 Bridged 350x2
2 Cadence 175.4 Bridged 350x2
Audiomaxx and Stinger 0,4,8,12 awg wires
Dynamat sound deadeners
My Build Log: http://www.stevemead...__+1999 +nissan
Does it blow the fuse immediately or after playing for a while?
If immediate disconnect speaker wires and RCAs and see if it will power up.
If after playing for a while switch the subs from amp to amp and see if it's a load problem.
Static drops are my bag.
Tried disconnecting the speaker wires and turned it on and stil pops the fuses. Opened the amp and checked the pcb and everythings good nothings fried or something broken
Nissan Frontier
10" Cadence Midbass
8" Cadnece Midrange
Bullet tweets
Mechman 270a
is there frayed wire strands poking out from the power or ground or remote or speaker terminals on the amp?
if no
are you sure?
there is no wire strands touching the ground and power wire and the remote wire is clean. is it possible the power supply shorted out?
Nissan Frontier
10" Cadence Midbass
8" Cadnece Midrange
Bullet tweets
Mechman 270a
help anyone? :(
Nissan Frontier
10" Cadence Midbass
8" Cadnece Midrange
Bullet tweets
Mechman 270a
If there is nothing but power, ground, and remote hooked up and it's blowing fuses it's broken.
help anyone? :(
Are the amps grounded properly? What size power and ground wires are you using? Is the 300amp fuse overkill? What kind of amps are they? The fuse in the one amp is basically experiencing excessive current flow. Have you looked in the owners manual to make sure you are using the right size fuzes. Is the amp screwed down to anything metal or wet? 90% sure you have a bad amp but you might as well try everything. Try switching the two amps around and see if the other one will blow on the "blowing" wiring (hopefully that makes sense). If it does, then there is a short in the wiring somewhere. If it doesn't short, then it is the amp.
2009 Nissan Maxima SV Super Black KH3
  • Hardwired Beltronics 955 Radar
  • Pioneer DEH-M9400BH with Stock Bose Speakers
  • Custom fiberglass HVAC display
  • Nexus 7 Tablet w/ Custom Fiberglassed Magnet dock
  • KnuKonceptz Big 3 and wiring
  • 2 Alpine Type E 10's with Alpine MRP-M500
Build Log HERE
Possibly cracked power supply, that's how my old RE amp went.
2003 Kia Sorento
Team Subsonic Lows
Team Bassin' on a Budget
  • 3 weeks later...
problem solved :)))) it was the relay that was broken
Nissan Frontier
10" Cadence Midbass
8" Cadnece Midrange
Bullet tweets
Mechman 270a
  • Who's Online   0 Members, 0 Anonymous, 636 Guests (See full list)
