Deadly hertzz Posted January 23, 2014 Report Posted January 23, 2014 I can run 4 at 1 and 8 at .5 correct? 8 sundown sa 12s walledSaz3000 at .5HO altAll ofc Sky high wireAlpine componentsRockford power mids
Joe X Posted January 23, 2014 Report Posted January 23, 2014 Yes, 2 ohm coils in series subs in parallel.
Deadly hertzz Posted January 23, 2014 Author Report Posted January 23, 2014 Sweet I'm runnin 4 I was gonna run 6 at .67 but I found a deal and might be going with 8 8 sundown sa 12s walledSaz3000 at .5HO altAll ofc Sky high wireAlpine componentsRockford power mids
Joe X Posted January 23, 2014 Report Posted January 23, 2014 Ok, just figure if you can have 14-16 cubes net with 220-260 square inches of port area.
Deadly hertzz Posted January 23, 2014 Author Report Posted January 23, 2014 Yeh I goda do some more measuring id rather have 6 in a good wall than 8 in a choked wall 8 sundown sa 12s walledSaz3000 at .5HO altAll ofc Sky high wireAlpine componentsRockford power mids
Deadly hertzz Posted January 24, 2014 Author Report Posted January 24, 2014 Rough measurements without trim out. 17x51x44 could I work with that that's like 22 cubes if my Maths right before displacement 8 sundown sa 12s walledSaz3000 at .5HO altAll ofc Sky high wireAlpine componentsRockford power mids
Joe X Posted January 24, 2014 Report Posted January 24, 2014 44x51x17.5 with a port area of 223.5 square inches will result in a 14 cubes net @ 33Hz box, about 1.75 cubes net and 28 square inches of port area per sub. (double layer baffle and 3/4" wood). Everything fits in the baffle but with a vertical all across port it results in a 8:1 area ratio which is near the 9:1 limit.
Deadly hertzz Posted January 25, 2014 Author Report Posted January 25, 2014 If you get a chance could you work me up a plan I been tryna use sketch up an not awesome at it yet, I was thinking if I could go port driver side that way I don't have to worry about leaning the seat back n to subs, this is def my biggest build yet I'm ready to knock it all out 8 sundown sa 12s walledSaz3000 at .5HO altAll ofc Sky high wireAlpine componentsRockford power mids
Deadly hertzz Posted January 28, 2014 Author Report Posted January 28, 2014 44x51x17.5 with a port area of 223.5 square inches will result in a 14 cubes net @ 33Hz box, about 1.75 cubes net and 28 square inches of port area per sub. (double layer baffle and 3/4" wood). Everything fits in the baffle but with a vertical all across port it results in a 8:1 area ratio which is near the 9:1 limit. 8 sundown sa 12s walledSaz3000 at .5HO altAll ofc Sky high wireAlpine componentsRockford power mids
Deadly hertzz Posted January 28, 2014 Author Report Posted January 28, 2014 Could you help me with a cut sheet with those dimensions all the port calculators I use online keep showing me dif lengths for some reason 8 sundown sa 12s walledSaz3000 at .5HO altAll ofc Sky high wireAlpine componentsRockford power mids
